15x10 5.5" backspacing
They're 1.75" backspace. They just looked tucked in because the car has no brakes on the front, so the wheels are bolted right to the hub. With brake discs on they would be out farther. When Trigger gets his front suspension done, they will look killer all tucked in!
I ended up getting a set of 15x8 with a 5.5 BS. Got these for a steal. After seeing those pictures you guys posted and reading your thoughts on the 10s, I will definitely be picking up a set down the line. Any pictures of the car on a lift with these wheels on a narrowed rear end? im curious to see what it looks like
Most have trimmed that area and hammers the metal back from what I've heard. Car is not tubbed at all and the tires are 275/60. These shots are a little different now since we lowered it a bit more by taking the shock rubbers out.
#34
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
i ran that wheel with a 28x10x15 i had to cut the body in the rear wheel well towards the front and i also have to cut the metal that encases the spring with that done they tucked real good and no rubbing
#37
how are you ppl running 4.5 bs and not minitubbing and narrower rears. excuse my retardness. what would i have to do to run a 5.5 and not minitubb. If it is maybe 2 inch narrow each side wouldnt a 5.5 bs work to get it in a stock location.
#38
if you narrowed the rear 3" on each side, a 4.5" bs with a 15x10 wheel would put the wheel exactly how it is stock. if you narrowed the rear 3.5" each side and used a 4.5" bs 15x10 wheel, it would tuck the wheel 1/2" inward with minor modifications. Anything more than a 1/2" tuck would require you to mini tub.
#39
#40
you could run a 5.5 easy 4.5 will require some work as stated above but will fit fine
