15x10 5.5" backspacing
#61
hi i got a 94 camaro with 15x10 with a 7.5 bs and what size ties max can i run without a mini tube mabee a little cutting. i have 28-13.5-15 and they fit but how much will they expand when i get on them.
#63
help i have a 94 camaro with 15x10 with a 7.5 bs. with 28-13.50-15 mt what do i need to do to get these to fit and not rub anywhere. are these going to expand more than 28" or what? did you guess do to get yours in there
#65
a guy in my town
15x10 5.5 bs stock rear
http://viewmorepics.myspace.com/inde...101&i=46439406
http://viewmorepics.myspace.com/inde...101&i=46439411
#66
i got them in there with a 3/4" spacer the only thing that i can see is right in front of the tires on the quarter panel its about 1/2". do people flare the quarter panels out or will they fit. and how hard are the wolfes mini tube s to do any susgestions and are the spacer leagal at the track if i put in 3" studs and open shanks
#68
LS1Tech Co-Founder
twin turbo 383 lt1, if it was my car I'd run those tires and then get narrower ones next time. If those are ET Streets, they are are as wide as 28W. They will stick out a bit. Take some pics.
#69
[![](https://www.youtube.com/watch?v=xTv_Uh3fIXg)
here is my car with the tires in are they to close they're brand new and i dont want to pop them i got a 3/4 in spacer in there right now and thats where they sit any susgestions thanks
#70
a guy in my town
#74
its was a 94 camaro z28 befor the knife and what the hell would you guys do? are the tires to close on the inside, i cant **** them in anymore so what would you do? a mini tub. and are they going to rub? the turbo setup is about done in 3 to 4 weeks at most and i need this thing to hook leaving the gate on full boost. i got everthing for the suspession i just never ran 15" rims with wrinkle walls
#75
so how would you guys solve this problem? are the tire just to wide for the car or rims. what tires and rims with what bs are you guys running on you 9 sec club car?
#77
what looks terible? the clearance on the inside. i dont think they stick out that far. imo but can i run 1" spacers at the track and put in 3" studs so there is enough of the stud left. then the clearnce would be bigger on the inside. but i hammered the inside as far as it will go. i have to start cutting to get any more. i cut the rear end stopersout on each side that opened the inside up a little. but give me your opinion
