i wanna see under the top 275 cars :)
#41
No, the front rod end threads to about 6-8inc lenth of thick tubeing with the smooth OD. And the front on the TA has a smooth ID that tube slides into (grease it) so as it gose thu the arc of the LCA it telescopes in length. Sliding to make up the arc diffrence.
Its the forth/loft (somthing like that) motion of the TA car, diffrent the a latter bar and a 4link setup. Without it there is a bind if you have a fixed front mount.
And they say, the TA can still be in a bind unless you have the rear upper and lower bolts nertral. Thats why the madman TA has the adjusters upper and lower. I dosnt see how the TA could be in a bind within its self, being a fixed triangle. But thats what guys get these them to work say, so Im going with it.
#42
[QUOTE=DanZ28;12730609]Do these help you at all? Few shots of my 275 build...
What is that U shaped thing hanging off of the bottom of the rear?
Is that for jacking up the car?
I've got to tell you, this car looks off-the-hook.
If this is the engineering that is going into 275DR cars, I am in big trouble!
What kind of rear is that?
Who is making all this custom equipment?
I thought I would step up to the M9, from my Moser 12 bolt, but even that looks outdated compared to that rear.
I may as well stop my planning and go back to Index racing. LOL...
PS. Would this car be legal in a "stock style" suspension class?
I would guess yes, since it does not have coil-overs?
#43
The rear, suspension and all cage work was made by Mike the owner of Enterprise Motorsports.
The rear started out as a standard HD 9" housing only (no axle tubes or anything) and he just built everything else for it except the sway bar but he even added bars to that. I didn't want any rear end problems so I wanted this thing beefy, plus I wanted something I could step up to a bigger tire later if I wanted .
That hoop hanging down is for jacking and also for tieing down the car.
Yep, It's still legal for stock style suspension too.
There are many different kinds of 275 classes, the one I will run though is more like an Outlaw or Extreme 275 and pretty competitive with several fast cars.
I'm sure you will do fine with your choices and be competitive, stay heads up racing! Also, the M9 is a nice rear, you should be fine...
#47
anti roll
what about antil roll bar? stock suspension or not?
I see "aftermarket sway bar OK". does that pertain to anti roll bar as well?
#48
Yes, my fab guy is a mopar fan, so he made it an upside down mopar "M", lol. He's actually building a twin turbo Hemi Firebird that will be off the hook...
Yes, anti roll bar is legal. I would have liked to do a wishbone setup but don't think it would fly...
#49
The wishbone is a sketchy thing.. some will allow it some won't It's nice that it stops the rear from shifting side to side like we deal with due to the phb arc, only thing we can do is try to keep the phb in the shortest part of the arc as possible to reduce the problems that causes.
PHB is probably stronger then a wishbone if the car gets way out of shape too though, as long as the mounts are boxed and braced right, wichbone's don't have much in the strength department if the car gets sideways.
I wanted to put one on mine believe me... but I'm holding off on that just because I don't want any issues. The PHB will stay.. it's getting moved back a little bit to clear the coilovers, but it will be there, attached to at least 1/2 the factory mount
#51
Coil overs in the back control the housing a little better, instead of having the forces multiplied because of leverage, now it's the other way around, if that makes sense. Ease of adjustment, the springs aren't in the way of hitting the tires anymore, easier to make ride height changes, lots of advantages.
#53
#59
#60
This is what we used .... didnt have to do anything but bolt it in.
Had it for 2 years now, no problems.
Webought the Afco double adj. shocks and springs from Madman. He gave us some starting point for the shocks and they were right on from the get go.
