Drag Racing Tech
What should I upgrade first...transmission or rear end?
Old 02-04-2010 | 08:08 PM
second_2_none's Avatar
Built trans first. I put a 4400 stall in my stock trans and it started slipping bad after my first time out. I have the stock rear and am cutting the times and 60' in my sig still no problem. Now if you had an M6 I would deff do the rear first. But auto's have a lot more cusion on the rear cause they always have pressure on the gears, they dont have that shock from dumping the clutch.
Old 02-04-2010 | 11:50 PM
kmracer's Avatar
i say trans too, autos' are soft on rears. stick with slicks though if possible, dr's are more likely to break ****.
Quick Reply: What should I upgrade first...transmission or rear end?
