ABS delete
I have found write ups on 3 channel.
Are the 2 front brake lines 6mm and the 2 rear 3/16?
The line from the master(rears) seems bigger than the rest.
any help will be appreciated.
Please leave this in the drag racing section,it will get more responses.
Thanks in advance.
Sean
If the lines from the master ar etoo big for the 3/8" fittings, drill the fittings a little bit to see if you can fit the line in. If you put on a 1/4" fitting and there is too much space you will leak like I did for a while.. until it fixed itself... go figure
ALso...
I got all my stuff from Murrays.. but if you want metric stuff and conversion pieces you will need to go to a a place.. starts with an L.. i forget the name, not pep boys or autozone or murrays or trak auto.. hmm...
I'd try to use all standard fittings though..
http://www.mustangmods.com/data/440/absdel.jpg
The line front line from the master cyliner is 6mm. My 1/4" compression fitting worked fine. The rear is 3/16".
I made a post with all the info. If you can't find it I can repost.
