Drag Racing Tech
How bad is it to lower car??
Old Jan 28, 2010 | 02:00 PM
AChotrod's Avatar
yup and they already showed up!! If its decent out Ill slap them in tomorrow.
Old Jan 29, 2010 | 11:19 AM
robsquikz28's Avatar
Nice and post pix!!
Old Jan 29, 2010 | 02:15 PM
blown03mustang's Avatar
im runnin strange DAs with a hotchkis spring in the rear. Hooks like a mother, rides pretty good and to me sits perfect.
Old Jan 29, 2010 | 02:40 PM
Fireball's Avatar
you'll need to relocate your LCAs if you lower...other than that...doesn't really hurt...mine's in the weeds...
mid to low 1.30 60's
Old Jan 30, 2010 | 02:24 AM
daniel6718's Avatar
relocate as in relo brackets or the front mount?
Old Jan 30, 2010 | 02:28 AM
lemons12's Avatar
High 1.4 short times on motoer, nothing special just a normal heads 226 cam car.
I have full adjustable suspension but I do not have relocation brackets. My rear was 1* off when I got my 4 wheel alignment done.. Checking pinion angle this week.
BTW, BMR 1" springs.. Stock shocks up front 3 way adjustable rear..
Old Jan 30, 2010 | 09:50 PM
BIG_T's Avatar
AChotrod where did u order just the rear hotchkis springs at?
Old Jan 31, 2010 | 12:00 PM
AChotrod's Avatar
Jegs, they were here in 2 days.
Old Feb 1, 2010 | 06:30 AM
Fireball's Avatar
relocation brackets...I had mine lowered so much that I had to custom make a set to get the geometry right...
Old Feb 1, 2010 | 06:46 AM
JL ws-6's Avatar
Race your car!
Question: Fireball, when you mae yours, did you put the holes in an arc, so that you can change the arm angle without changing the length/having to resquare the rear? I was plannign on doing this, but wasn't sure how hard it would be. Several holes, close together, and in the same arc the rear moves in.
Old Feb 1, 2010 | 08:38 AM
Fireball's Avatar
I just made it by hand so I didn't bother with an arc. when I redo them this time on a CNC, I will have the arc.
Old Feb 1, 2010 | 09:31 AM
  #32
JL ws-6's Avatar
Race your car!
When you redo them, hit me up< I might be intrested in a set of you can cut 2. I wanted to put 4 or 5 holes in them, and have them as close together as possible, so there's more options for adjustment.
Old Feb 1, 2010 | 10:50 AM
  #33
AChotrod's Avatar
How are you guys that are sitting really low getting on your trailers?? It was already kinda tight for me on all the local rental trailers using long 2x8s
Old Feb 1, 2010 | 11:50 AM
  #34
JL ws-6's Avatar
Race your car!
My trailer has an extra 6 inches of height, so the door's already 6 inches longer due to that, plus I have a 2.5 foot long ramp extension inside the trailer that folds out so the door is a total of about 9 feet long. Couple that with the beaver tail that is in the trailer, the slope is pretty forgiving for loading the car.
I also have some 2x8's that I may or may not need once I lower the car to where I want it.
My old Birmar I used to use 2 3 foot long sections of 2x10 along with a small support in the center to help get the nose up some before the trailer. One other trick, is to put a set of the cheap walmart plastic ramps in your truck bed, and when you get to the track, put them behind the rear tires, and back up on them. that will help pitch the trailer downwards, making the slope more forgiving as well.
