Drag Racing Tech
has anyone removed this stuff to save weight see pic
Old 01-28-2010, 12:45 PM
LadyDriven's Avatar
Ahhhhh! I'm in the middle of removing that crap from my car right now as well. Originally it was just to take those extra couple ounces out, but now I'm also doing because it'll look MUCH better with all that crap gone. I'm just using a wire wheel on a cordless drill, and its coming off quickly, but flinging EVERYWHERE. The entire inside of my car is covered in yellow "snow". My clothes and shoes were full of it as well. Fun stuff...
Old 01-28-2010, 12:53 PM
nemss1's Avatar
BLK:UFO, here is a pic of mine. still a lil rough. i need to grind smooth the rough edges and weld the holes from drilling the spot welds
Originally Posted by stangeater01
is the weight worth the effort?
im gonna have to say yes on this one. ounce per ounce, pound per pound...it all adds up. the most mass off of my car was crap that weighed 5lbs a piece
Old 01-28-2010, 12:59 PM
nemss1's Avatar
Originally Posted by JL ws-6
I'm going to just get a hole saw and get to that interior panel where the speaker was. Couple different sizes so I can try to get a good bit of it out. That way there's still a little support there, going to do it after the minitub is done.
someday when I redo the cage to a 25.x I'll probably convert to a hardtop at the same time, at that point I'll hole saw under the roof like I've seen a few people doing now. That's alot of work though for the return. Hardtop, will save a good bit though over the t top weight I think.
JL, im sure you'll be fine removing that whole panel. it is very flimsy, small gauge sheet metal.
most of the support in that area, is the tick, gauge support metal which you can see in my and BLK:UFO's pics
Old 01-28-2010, 04:59 PM
Banned Village Idiot LS1BLKSS
BLK:UFO's Avatar
holy **** bro i didn't know i could go down that far good job!!!
Old 01-28-2010, 05:02 PM
stangeater01's Avatar
it probably doesnt weigh much more than the pad on the brake pedal i had my formula to 2750 lbs and didnt have to take that out
Old 01-29-2010, 12:14 PM
nemss1's Avatar
haha ya that whole panel comes out as one piece. thx man
Old 01-29-2010, 12:17 PM
Race your car!
JL ws-6's Avatar
Could you get a pic of what's inside there, by the wheel well? I want to see the metal that's the wheel well, but so I can see what's behind that panel.... if you have the interior apart and the camera handy
Old 01-29-2010, 12:25 PM
nemss1's Avatar
ya ill snap a pic. interior is still apart and a cam is always handy.....just have to muster the heat and energy to step outside in this freakin blizzard
Old 01-29-2010, 01:18 PM
nemss1's Avatar
structural support metal for the quarter area
yes, that is freakin blizzard on the car til the shop is finished
Old 01-29-2010, 02:43 PM
02Z28's Avatar
its a white v6 98 camaro roller, it doesn't look like it has been redone, i just tired taking it off its kinda a bitch but its coming off, im using my angle grinder with a 80 grid disk... what did you use Taubr Unit??
I heated mine up with a little torch then wire wheeled it off. With the heat it came off a lot easier.
Old 01-30-2010, 12:09 AM
DanZ28's Avatar
JL, will that fly in stock suspension classes/25.3 like the above pics? Plus it looks like you may lose the ability to mini tub it properly...
Old 01-30-2010, 12:52 AM
  #32
nemss1's Avatar
i dont think it wouldnt affect classes. its just a flat piece of sheet metal to hold the quarter midbass subs/speakers. not meant for structural integrity. now the piece behind, is part of structural integrity. its really thick gauged support frames for the quarter area. without that, the rear fenders would wrinkle all to hell. minitubbing will be just fine. just a more open area and more of the tub will be visible without that piece of sheet metal
Old 01-30-2010, 09:08 AM
  #33
Race your car!
JL ws-6's Avatar
Not sure to be honest, if it's just a piece like these guys are saying I can't see it making a difference.
I'm going to get the car minitubbed, and when that's done, I'll look at what's left in there and remove what's not needed. I think, that the arm rest pieces that these guys are removing come out to minitub anyway, and I think, that flimsey piece they're takign out is also just cut out of the way as well, but it may help support the minitub, not sure.
Old 01-30-2010, 11:33 AM
  #34
DanZ28's Avatar
The mini tub and the 25.3 spec was my worry, didn't want to add the rear bars if I can leave all the rear structural pieces in place and pass the car the way it is, thanks.
Old 01-30-2010, 01:21 PM
  #35
nemss1's Avatar
i dont think it supports the minitub in anyway. it doesnt seem to support the stock tubs. all its there for is to hold speakers and something for the rearseat brackets to mount to. if people are taking out rear seat brackets, then i dont think you have nothing to worry about. that piece is alot more of a structural piece than the flat sheet stock holding the quarter speakers
Old 01-30-2010, 09:25 PM
  #36
DanZ28's Avatar
ok, cul, thanks.
Old 01-30-2010, 10:55 PM
  #37
nemss1's Avatar
ok, cul, thanks.
no prob man
Old 01-31-2010, 03:04 AM
  #38
mighty-z28's Avatar
I'll suggest you to take the Reinforcement Bars from the doors, they weight a TON !!!
Old 01-31-2010, 08:42 AM
  #39
JFM-jr's Avatar
About 7 lbs each side
Old 01-31-2010, 11:20 AM
  #40
mighty-z28's Avatar
No way !!! Those bars are at least 12 each !!! I throw away mine so I can't check it, but I remember that it was very heavy !!!
Quick Reply: has anyone removed this stuff to save weight see pic
