Drag Racing Tech
Aluminum Guage Panel>
Old Dec 28, 2003 | 10:06 PM
Billingsley Racing's Avatar
Default Aluminum Gauge Panel>
To compliment our popular HVAC block-off plate, we now have an aluminum plate that replaces the HVAC control panel and accepts 2- 2 1/16" gauges. We use a specially designed die to countersink the gauges into the plate so that the plastic trim panel does not need to be trimmed.
HVAC Gauge Plate
Check it out.
Thanks
Old Dec 28, 2003 | 10:18 PM
The Guy in MY 99TA's Avatar
Thats nice! But I plan on keeping my a/c and stuff for a while so no need for it now.
Josh S.
Old Dec 28, 2003 | 11:20 PM
02redSS's Avatar
anyone make a gauge panel to replace the vents?
Old Dec 28, 2003 | 11:27 PM
White98Z's Avatar
How does it bolt down does it have pree drilled holes the same as the thing removed. Should have had this 2 weeks ago when i ordered the plate for the fire wall.
Old Dec 29, 2003 | 06:55 AM
DOC OTIS's Avatar
Nice pics Jay! This piece fits very well and looks outstanding in the car.
Old Dec 29, 2003 | 07:02 AM
Reckless's Avatar
Super Moderator
Nice effort Jay What I'd like to see is a plate that inserts into the factory gauge location in front of the wheel. This way folks can replace the factory stuff with after market gauges without fabbing something up. Any chance of seeing that?
Old Dec 29, 2003 | 07:33 AM
Big Mike's Avatar
Very nice work! I'll be ordering one of those soon, as well as the HVAC blockoff plate.
Old Dec 29, 2003 | 10:21 AM
squinn's Avatar
I'm looking for the same thing Todd, I was thinking madman made one?
Old Dec 29, 2003 | 11:16 AM
Big Rick's Avatar
Madman does. Look up "Big Shows" old ride.
Old Dec 29, 2003 | 12:54 PM
The plate is pre-drilled to fasten using the 2 existing screws.
Thanks
Old Dec 29, 2003 | 04:01 PM
Reckless's Avatar
Super Moderator
Problem with Madman is that his web site sucks harry ***** If he would put the things that are available, he would sell more IMO
Old Dec 29, 2003 | 05:53 PM
The Juggernaut's Avatar
I'll be calling you soon ,Jay.
Old Dec 29, 2003 | 07:35 PM
02 Silver Z's Avatar
Looks good. I like my A/C block-off, I think I`ll be picking one of these up also. I would spend that much money in gas just trying to chase down all the stuff to make my own. Yep, I`ll be calling!
Old Dec 29, 2003 | 08:50 PM
sawedoff's Avatar
I'm liking this stuff. Here's an idea that I've been toying with and maybe you guys could do something with. The airbag on the passenger side is usually removed in a racing car. This then leaves a nice empty space that's not too attractive. What about designing another place to mount guages using this area? Naturally the space would have the guages positioned towards the driver, and look aesthetically pleasing. It could be either out of aluminum or a material that looks very close to the a pillar plastic.
Old Dec 31, 2003 | 03:39 AM
MUSTANGEATER's Avatar
Isn't that your car in that pic?
Old Dec 31, 2003 | 04:05 AM
DOC OTIS's Avatar
Old Dec 31, 2003 | 09:03 AM
Camaroholic's Avatar
Huh? Only if you remove the airbag cover (which is glued on to the dash). The cover weight is minimal. The airbag rests under this cover, and the airbag can be removed without leaving any outside visual signs at all...
I like the blockoff plates. I think my HVAC is coming out in the spring... I'll be calling. 3300 or bust.
Andrew
Old Jan 1, 2004 | 09:15 AM
theblur98ss's Avatar
I'd also like to see one of these that fits in the vents. I may have to try some custom fabbing.
Old Jan 5, 2004 | 09:02 PM
TOSTO RACING's Avatar
Nice work Jay
Tim
