Drag Racing Tech
Wheel Studs
Old Mar 8, 2010 | 06:31 AM
Ram4whldr's Avatar
Default Wheel Studs
I ordered my Moser 9" last week and went with 12mm long studs. I would like to get the front studs to match and pass regulations. Could someone help me find the part number for the front studs I need to order from Summit? I called and they couldn't help me unless I removed a stud and measured it. Thanks in advance.
Old Mar 8, 2010 | 06:33 AM
JL ws-6's Avatar
Race your car!
You need the 12mm long ARP studs, that are 3 inches long. That will stick out of the lugnut enough so no tech guy is ever going to harrass you about stud length. You "might" be o.k. with the 2.5 inch length, but the 3 inch will 100% be enough.
I hope that helps, if you go on summit's website, look for a press in arp 12mm 3 inch long stud, you should be able to find them I think.
Old Mar 8, 2010 | 09:39 AM
Ram4whldr's Avatar
Thanks for the advice. The only problem is the Moser I just purchased is coming with 2.5" studs and I would like the fronts to match.
I think I found them finally. ARP #100-7708.
Old Mar 8, 2010 | 09:50 AM
trigger1's Avatar
Well simply pull your rear axles and replace the studs? Or call them up and see if they can go ahead and build it with the longer stud.
