Drag Racing Tech
cage/subframes tied together
Old Mar 9, 2010 | 01:59 AM
daniel6718's Avatar
Default cage/subframes tied together
what setups do yall guys have? and how did yall tie them together?
does the cage go though the floor all the wat to the sfc or did you weld cage to a plate then weld sfc to another plate underd the car?
im wondering what to order, since im goana tie it all together i was thinking spohn CM SFC with a wolfe CM 6 point not jig notched so we could still tie them together
Old Mar 9, 2010 | 08:12 AM
tee-boy's Avatar
bump for you
Old Mar 9, 2010 | 09:58 AM
sweetbmxrider's Avatar
why not get wolfe sfcs?
Old Mar 9, 2010 | 10:18 AM
daniel6718's Avatar
thought about it but seem to be more labor to install and overkill if im planning on tieing it all together anyways...plus it would all be chromoly to tig together
Old Mar 9, 2010 | 11:00 AM
Mikey 97Z M6's Avatar
I think 98% of the caged cars on here have 6x6 plates at all rollbar/rollcage mounting points, as well as mine.
Mike
Old Mar 9, 2010 | 12:31 PM
daniel6718's Avatar
is it tied to subframes?
Old Mar 9, 2010 | 01:12 PM
It's not directly welded to the subframes.
Mike
Old Mar 9, 2010 | 01:22 PM
camscam02's Avatar
we plan to tie our 10 point into the subframes by going through the floor and straight to the umi round subframes. That is the plan at the moment.
Old Mar 9, 2010 | 02:33 PM
Fireball's Avatar
this is a matter of rule interpretation...
by the rulebook, unibody cars must be welded to 6x6 plates on the floor...so even if you go thru the floor to a subframe, you may still need a plate there too.
on full framed cars they go to the frame...but a unibody for SFCs is still not full-framed...
Old Mar 9, 2010 | 03:24 PM
tee-boy's Avatar
Default dfdfdf
are your sfc's tied in?
Old Mar 9, 2010 | 04:06 PM
you could just run some round bar with a plate to the floor pan under the cage mounting area. the best advice i heard is to have your mounting plate extend through two axises if i'm terming that correctly. like in the pic above how its on the flat top part of what i believe is the torsion box (i'm really not good with terminology ) and then extends down the backside of it.
Old Mar 10, 2010 | 05:02 AM
Fireball's Avatar
I have a 25.x spec cage...we are required to tie in...but not in the way traditionally done.
Old Mar 10, 2010 | 08:16 AM
tee-boy's Avatar
Default fdfdfd
I've read the 25.5 SFI Spec. I didn't see anything mentioned about subframes. you must be doing a 25.2 or 25.3.
Old Mar 10, 2010 | 08:47 AM
Fireball's Avatar
look at bars 2A and 2B on the 25.5
By design they are supposed to ultimately tie into the subframes
even then, the rocker bars run in between the OEM subframes which tie everything together.
Old Mar 10, 2010 | 09:37 AM
tee-boy's Avatar
You're rocker bars are above the floorboard, right?
Are 2A and 2B needed if using the OEM firewall and trans tunnel?
Old Mar 10, 2010 | 10:45 AM
Fireball's Avatar
yes...above the floorboard
they are always required in 25.x spec cages.
Old Mar 10, 2010 | 12:29 PM
tee-boy's Avatar
Default dfdfd
got you. see it now in the book.
Old Mar 11, 2010 | 07:53 AM
mad_steve's Avatar
We always just go to the 6x6 plates welded to the floor. Anything more than that is overkill.
Old Mar 12, 2010 | 09:49 PM
redtransam95's Avatar
nice cool
Old Mar 12, 2010 | 10:42 PM
daniel6718's Avatar
so cage w/plates no subframes?
