Notching interior door locks on wolfe door panels
What else did you have to trim to get these panels in? It looks like I need to cut out the two center mounting points that attached to the original door panels.
Thanks, Matt
Did you keep the triangle of rubber weatherstripping on each side?
Will the rivets hold up on the SMC of the doors?
I didn't use the rivets, I used nylon anchors on the door perimeter and used flathead screws instead, that way I could take the panel off without drilling out rivets if need be.
