Drag Racing Tech
m6 on 10 bolts
Old Mar 26, 2010 | 06:28 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Originally Posted by TOSTO RACING
I just had a 1.68 60 on hoosier qtp's and a 3500 rpm dump. I had a 1.70 when I was slipping the clutch out ,but the stock clutch once its hot is toast so dumping it fixed me up for the night. I have been 1.53 on a stock 10 bolt and et streets on the spray in my old 6spd car at 3600 lbs. I went 10.95 at 122 on that pass and drove it home. I considered myself lucky that night lol.
One thing I noticed that is a GM untouched 10 bolt tend to live longer then something fitted with a aftermarket gear set, must be something just in the torque specs, and tolerence.
Old Mar 26, 2010 | 06:35 PM
ATwelveSec02Z28's Avatar
Originally Posted by 99TransAmLS16Spd
You're not getting the point.... Not everybody has $2,500-$4,000 to throw at a stronger rear end set up. I do not professionally race my car, but I do love test n tunes and midnight events. I see SUVs running 16s at these events. I consider my low 11's fun - even if I wasn't at the "full potential".
If you're going to knock us for babying 10 bolts, then you're basically knocking everybody running a stock bottom end, or not running nitrous, not running higher stalls or taller gears, ect because they are not "learing how to race"
But you have a LME 400+" engine, Level 5 T-56, and a OZ700 clutch with a stock rear??
Old Mar 27, 2010 | 09:26 AM
TOSTO RACING's Avatar
I had 4.10's in it the only reason the stock untouched ones last longer is the 3.42 pinion gear is bigger there fore it is stronger.
Old Mar 27, 2010 | 03:56 PM
Internet Mechanic
I figured as much, makes great sense.
Old Mar 27, 2010 | 10:58 PM
99TransAmLS16Spd's Avatar
Not anymore - I've upgraded to a MWC 9" spool, 4.11 aluminum strange center, 35 spline axels - the works. Haven't been to the track with it yet. I'll also be running 28" stiff side wall slicks...should make for some good et's. The ten bolt I had had a mac cover, welded tubes, motive 3.73 gears, and ran on royal purple - so it wasn't stock but also didn't have too much money into it.
My point to the other yo yo was, who the heck is he to tell me what I can and can't race? I was running very low 11's on the ten bolt- which was quicker than many of the guys with upgraded rears. And it made sense to me to get my motor combo together first so I could deturming the best gear to run, instended of simply guessing.
Now that I've upgraded rear ends, is he going to tell me I need to upgrade to a solid roller to get the most out my combo? It kinda sound like he belongs in our current pool of politicians....
Old Mar 27, 2010 | 11:11 PM
Also, much of the reason you see sheared ring gears is because the axel tubes on a ten bolt flex (pull forward) on hard accel/load. This pulls the ring gear from the pinion. Take a look at pics of exploded gears - it's almost always the outer portion of the gear thats messed up - which is an indication of this happening.
This is where the cover w/ bearing support, welded tubes, and back braces come into play. Think about it - most after market rears come with a "backbrace" option, even though they use heavy tubing w/ a 3" diameter. The stock 10 bolt's tubing is thinner and I believe only 2 3/4" diameter
Old Mar 28, 2010 | 09:00 AM
Internet Mechanic
Sounds like you can't read.
But your an moron who wants to harp on one thing I did not even say. So that goes to show you the pool of talented, and knowledgable people on LS1tech has dwindle a great deal.
Sad to say I spoke with a few people, some are Mods here, and they said, stay away. Well I thought I could fix stupid but I guess I can't.
For the last time, this has nothing to do with running with the best parts to make the most out of the combo.
It has to do with racing a t-56 transmission on a 10 bolt rear. Its a recipe for disaster and you do NOTHING but waste money. Save for a good rear and go for a time slip.
But again, I do not expect you to come back with anything that actually makes sense.
Old Mar 28, 2010 | 09:40 AM
Look, I will agree with you that when you're running with a ten bolt you are on borrowed time - like you said. But simply because somebody chooses to run on a ten bolt (or cannot afford an aftermarket rear), and takes it easy on their launches does not mean they are a moron.
I know i did not get the most out of my engine last year because I had to go easy on the launches. But I do feel I got the most out of my combo. Just like the guy limiting the spray on their stock bottom end, I had to limit my launches on the 10 bolt. I know it does not make sense to everybody. But in my case, I felt it made more sense to take advantage of the sale prices I got on my T56 and 416 - which saved me $2000 instead of not getting one of those two and buying a rear end instead.
And it worked out for me in terms of et and mph. I could have bought a rear and not the engine, and with my old combo maybe would have ran an 11.3x but with a real stong 60'. But instead I went the engine route and ran 11.0x's - 11.1x's with weak 60' times. Which one wins in a race?
