Drag Racing Tech
6 speed guys with MSD 2 step
Old Mar 28, 2010 | 09:06 PM
jmm98LS1's Avatar
Default 6 speed guys with MSD 2 step
How are you guys wiring the 2 step activation into the clutch pedal? Are you using one of the factory clutch switches or adding another external switch? I hate wiring, any guidance is appreciated.
Old Mar 28, 2010 | 11:25 PM
Zmg00camaross's Avatar
Well i mounted on the pass side and ran one wire under the pcm thru the access hole. And wired to the factory clutch switch if i not mistaken it was a 4 pin connector and it was a brown wire.
Old Mar 29, 2010 | 05:54 PM
SmokedOutZ28's Avatar
I have mine ran the exact same way..... I believe mine is a grey/black wire. I'm also running a external switch to turn it off.
Old Mar 29, 2010 | 06:28 PM
DopdBrd's Avatar
So will it arm every time you depress the pedal? how does it work?
Old Mar 29, 2010 | 06:51 PM
Yeah i forgot what wire it was but its on the 4 pin connector. and yes everytime you depress the pedal the light should come on the msd box, and when you set the 2 step at desired rpm and floor it it studders. again cant remember think it was the Ground side of the msd box.
Old Mar 29, 2010 | 11:31 PM
DiabloFormula's Avatar
I see you have a 98, which do not have the four pin connecter, use the lower clutch switch and tap your 12v activation wire from the msd into the purple/white wire.
Old Mar 30, 2010 | 04:26 PM
jmm98LS1's Avatar
Excellent, thanks for that! Is this how you have yours and it works? So I need to tap into the purple/white wire and not the dark green wire? I'm looking at a wiring diagram of that circuit right now and it shows switched 12v coming into the purple/white wire and when the clutch switch closes it sends 12v through the dark green wire which powers the starter relay.....so according to the diagram that switch only gets 12v during start conditions?.....
Old Mar 30, 2010 | 05:44 PM
DopdBrd's Avatar
I'm a little slow today, what keeps it from applying 12V everytime you hit the clutch, instead of just when you launch the car?
Old Mar 30, 2010 | 05:45 PM
You are correct, so when you have your clutch pressed in the 2-step will be activated, this is how I have mine hooked up and it works great......enjoy!!
Old Mar 30, 2010 | 05:48 PM
It doesn't......but think about it, when are you ever going to rev the car up to say 5-6K unless you plan on launching, if you don't plan on racing one day or just driving around the town, all you have to do is set the MSd to like 8K, which you'll never rev to anyways.
Old Mar 30, 2010 | 07:53 PM
I have a switch wired in to turn it off when driving around town, But even with it active my 2-step never engauges unless you shift gears with your foot on the gas.
Old Apr 7, 2010 | 11:03 AM
jmm98LS1's Avatar
I tried tapping into both wires coming out of the clutch safety switch and it just wouldn't work. Ended up just removing those wires from the safety switch and splicing them together (car starts without clutch pedal pressed now). Then I ran a switched 12v source and the 2 step activation wire to the old safety switch on the clutch pedal. Works good!
Old Apr 7, 2010 | 11:13 AM
AChotrod's Avatar
I run mine off a momentary button on the Steering wheel. I dont like the idea it comes on every shift so I just use it on the line
Old Apr 11, 2010 | 05:22 AM
96LT1355Z28's Avatar
Same here, but mines on the shifter and is also wired in with the line locks.
Old Apr 11, 2010 | 02:14 PM
studderin's Avatar
I have the LNC but you dont have to go thu the firewall the get the clutch switch. I got it right on the PCM harness pin, everything is under the hood, easy hookup.
Old Apr 12, 2010 | 02:12 PM
wforty94's Avatar
is there anyway i can use one of the radio controls on the stock steering wheel to activate the 2-step? can anybody tell/show me how if it is possible?
Old Apr 12, 2010 | 03:30 PM
AChotrod's Avatar
Its possible I just didnt know how to do it. lol so I ended up making this thing
Old Apr 12, 2010 | 06:30 PM
airfix's Avatar
Hey Mike, Where did you buy that coiled wire? I'm putting in a 2 step the same way you are, but with a sparco steering wheel with a sparco horn button. Just need the coiled wire.
Old Apr 28, 2010 | 07:35 PM
stealthy_2005's Avatar
I wired mine in to my factory fog light switch. So I turn on my fog lights to arm it and then the hot wire on my brake lights is the activation. works GREAT! my car is an auto car but it would work on either application
Old May 11, 2010 | 08:32 PM
98mysticZ's Avatar
wired mine to the lower switch.. pulled out the connector and put spade connectors on it and ran it to ground so it will only activate with it on the floor
