Removing wiring, need ID on a part
Thanks,
Sean
if you're going race wiring, the only thing you need to worry about is turning off VATs in the PCM assuming you're ditching the BCM.
FWIW I'm doing the same thing (race wiring)
I measured 20lbs of wire
I have a ton more pics and info.
Im getting a spare harness to do this. get the AC/stock radio,ABS,foglights,Ebrake,airbags,ASR,rear02s, setabelt lights,washer, evap, other **** I cant think of right now.. haha
I went back to school to wrap up my masters degree and focused on some other things in life (career) but I'm finally getting back into it. I'm also not buying parts on credit card anymore, so it's taking a little longer than usual
I have a list of the pins I removed from the PCM, but I haven't fired up the engine with the current harness. Waiting to do that before I post the info.
Some teaser pics
