Broke trans tonight.
And if you are going to insist on leaving a stick in... you CAN do it, you're just going to have to shitcan the T56 and put a real racing stick tranny in with a softloc type clutch that's fork operated... then you can run with the stick, and just deal with the clutch.... but get ready to pull the wallet out and the plasma cutter for that ordeal.
OP... I'd get the tranny out, fix it and seriously look at selling it NOW, while it's fresh and in good enogh shape to bring some decent $. Better to sell a good part then have to fix it then sell it when it breaks again, and it's not IF it breaks again it's when...
I cam across a complete swap for a rossler 400 with brake and ati 3800 stall. I have just over $2100 in the complete swap
Best I went with the t56 was 10.30@137mph
made a few changed to the top end of my car but the same pulley on the blower and went 9.82@141mph 2nd full pass down the track this year. Have yet to go back as I need to get all my license stuff in order and head back to make my licensing passes
Swap is very easy. had to do some minor fabricating for my shifter mount and stuff like that.
How is the driving on the street with the auto vs the M6? That is one of my issues is not having the gear box on the street??? Also, do you have to swap the entire engine bay harness? I have alot of switches/guages ect hard wired into the factory harness and prefer to not mess with that right now. Just inbetween I guess.
The only part of the harness I had to mess with was the speed sensor plug. I needed a different plug on it. Also it is a a reverse manual so I shift the trans computer doesn't control any of it.
Highway driving sucks for me but I have 410s and a 26 inch tall tires, probably moving to 373 and a 28 in the future so I can cruise around 65 no problem, right now 55 is pushing the rpms higher than I would like.
i ended up going with a built th400. It should brake less, and is cheaper then the t56. Should be faster, and more consistant.Chris
