Drag Racing Tech
daily driver 60ft?
Old May 16, 2010 | 07:38 PM
30th6's Avatar
Default daily driver 60ft?
i want to no what is the norm for a dd street car i mean full interior,ac,radio street car is.mine is 1.6 for now the dam clutch kept welding together so couldnt leave but at 3k.new clutch im plannin on leavin at 5k on a 150 shot
is it possable to get a 1.4 on a full weight car?i have a bolton 140k mile ls1with a moser 9 in,lcas w/brackets,umi ta,sfc,cromoly ds,and stock shock/struts with 140k miles on them.what does most of yall run with simalier setups?whats the best this car should run?
Old May 16, 2010 | 09:39 PM
6techniques's Avatar
well 1.4's are def possible with enough power and a nice suspension setup. Have you looked around to get a good idea what similar setups are running? there are plenty of them out there
Old May 16, 2010 | 10:36 PM
c0ncEpT's Avatar
My buddy's H/C car 60's in the low 1.5x range and its a full weight pig weighing in at 3750 with him in it.
1.4's are very obtainable. You just need some power, a good suspension set up, and a tire.
Old May 17, 2010 | 05:43 PM
30th6's Avatar
well thats good to here i think i have the power now if it will hook.
Old May 17, 2010 | 08:14 PM
Randy WS6's Avatar
I cut a 1.39 60ft. on Hoosiers DR's.
Old May 17, 2010 | 08:37 PM
Sofls1's Avatar
I go consistent 1.4s usually 1.45 with my daily driver with a stock tq arm.
Old May 17, 2010 | 09:06 PM
30th6's Avatar
does 7.3x s sound resonable?i ran the times in my sig with two pounds in the bottle and clutch issues.how much would fats and skinnys pick me up in a 1/8th?im running roh snypers on the front 17x9s there aluminum but still heavy,and stock 16in 5 stars with m/t et streets on the back.
Old May 19, 2010 | 04:32 PM
DOUBT IT's Avatar
I've pulled 1.57's running SI on a Nitto to an 11.623.
My car should easily see 1.4x's on the bottle with a real DR.
I've seen 1.74's on a true street tire, en route to a 11.95 pass.
Old May 19, 2010 | 04:45 PM
SS4Luck's Avatar
im going low 1.6 with 68K mile stock suspension with a new torque arm cam only on m/t DRs with a 5K+ launch
Old May 22, 2010 | 10:27 AM
what is your suspension setup? how are you coming out of the hole? (shot, rpm's, etc)
Old May 22, 2010 | 01:44 PM
Sofls1's Avatar
Full weight car, Stock TQ arm w/ UMI relocation crossmember, BMR LCAs, Hotchkis lowering springs, KYB AGX rear shocks, 26x10 et drag, QA1s in front.
Stock LS6 w/ 150 shot SS3600 converter foot braking to 2000, Spraying it right out of the gate.
Old May 22, 2010 | 01:59 PM
BADD SS's Avatar
you have an auto, which makes life easy, op is a 6 speed car..... 1.4's in a full weight stick car, with bolt ons and a little juice will not be easy at all.
Old May 22, 2010 | 02:15 PM
Sofls1's Avatar
I would imagine it would be quite different than my setup. I noticed the OP was a stick car after my first post, I was just answering the question in the second.
Old May 24, 2010 | 05:44 PM
mike c.'s Avatar
I do 1.42 to 1.44 60's N/A m6 car that i can daily if i choose. however i do have a tub front end,no front sway and front runners on at track. I now have a lighter hood on the way,a ws9 outlaw and hope to remove another 25-30lbs off the nose. I make 530hp in a 402ci.
Old May 24, 2010 | 08:05 PM
30th6's Avatar
well thats a quiet a bit different than mine,sounds like ill be lucky to get a 1.5.why can a auto car 60 better (1.5) with a 2500 stall and a 100 shot? thats weird to me he did have fats and skinnys, very small amount of weight reduction and 410 gears but he ran a 7.53 on a 1.6 and i ran a 7.55 with a 1.6.is a 7.3x possible with my setup?
