Flexplates-Aluminum vs Steel??
Well you do need some weight to plant the tires but these are really heavy cars.
Reducing rotating weight is always a good thing and sends more power to the tires. Im not sure if a huge et gain will be noticed but for me its all about optimizing the setup. I dont mind skimping so much on easily replaced parts but if later on down the road I decide I want an aluminum flexplate I dont wanna pull the trans, rather spend the extra $$$ and do it right the first time.
Yes I felt that myself with stick, but in auto you can't bog to 1500-2000rpm because the converter won't let you
I wonder whether this flexplate will fit LS1...
http://www.ptcrace.com/tooth-internal-p-1275.html
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
