Drag Racing Tech
Heavy front end tips
Old Jun 6, 2010 | 06:45 PM
CyaPussy's Avatar
Default Heavy front end tips
I know there is alot of info under this section but just looking for any helpfull tips. I am running an iron block with a procharger. I have all after market stock style suspension parts. I know this is a broad question but figured some one can point me in the right direction.
Old Jun 7, 2010 | 05:34 AM
joblo1978's Avatar
That's alot of weight up front. Any weight reduction you can do will be a good thing.
Run 325 lb. springs instead of 300's if you ever go for drag springs.
Old Jun 7, 2010 | 09:23 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Well considering I owned a LT1 for years, being used to an Iron block was no biggie, even with putting on a FI setup like a Procharger.
LT1 springs were a little heavier then stock (i beleive 315-320#) and most times if you need to get weight off. People would xfer the battery to the back, and remove un-needed equipment such as fog lights, A/C unit, washer fluid/bottle, extra overflow coolant.
Whats the plan for the car?? What are you trying to accomplish.
Old Jun 7, 2010 | 10:11 AM
The Guy in MY 99TA's Avatar
the is always the lightweight spindles... but I don't like the fact that they are a 2" drop spindle... I personally don't like em lowered... for a race car anyway.
Old Jun 7, 2010 | 11:36 AM
94Z28rag's Avatar
I'm putting 275 lb springs in my LT1 with some weight reduction up front.
Old Jun 7, 2010 | 12:06 PM
Internet Mechanic
Another thing to note as I am sure you do not want to hear this, maybe its time to buy LIGHTweight aftermarket front end components. I.E. Chromoly. Sell the Mild Steel stuff.
Old Jun 7, 2010 | 02:34 PM
Steve Burger's Avatar
LS1TECH Sponsor
We can assist with lightening up the front end. We have a wide array of parts to take weight out and add strength. Let me know if you would like to talk over options.
Old Jun 7, 2010 | 03:05 PM
CyaPussy's Avatar
I have the 325 springs and most of they other things removed just dont like how the springs are almost all the way up the shock. I would like to get the car into the 9s with a six speed but i doubt that will happen.
