Drag Racing Tech
Swaping in a th400/350
Old Jun 16, 2010 | 06:59 PM
  #41
krissoto's Avatar
I also run a turbo in my ws6, it has the 9" tail, and I used the stock ds. I have the pro ratchet in my car w/ rmvb with a tb. I love it. I went with a trans specialties converter 3600-4100. The only thing that you might have to chk for with your build, the flexplate that you use might have to be shimmed, depending on how far the converter sits from the flexplate, and I had to use a spacer on my converter. It just slips on the little snout on the flexplate side of the converter. I cannot rem the specs of hand on whats it not suppose to be more that but maybe someone else can chime in and help you out. Some wires have to be cut and wired together to get the car to start as well. Ya I miss the od, but you cannot beat the performance or reliability.
Old Jun 16, 2010 | 07:25 PM
  #42
SuperSlow02's Avatar
I can honestly say my RMVB gets old, and i may drive the car 10mi a month, but thats personal laziness lol. I need to pull the converter out of mine, got it in the trade and decided to use it since I already had it, my car dosnt have enough guts to get out of the hole I guess..an amazing 1.78 60ft(flashing it, foot braking it, trans braking it, 2-step/TBin it) dead hookin everytime. Im thinking I have a short TS, but i like it better, I dont have to drop my tunnel mount torque arm to pull the trans now, ive got a good 8in or so clearance, with the t56 it was maybe 3in or so.
Old Jun 16, 2010 | 09:57 PM
  #43
sidewayz28's Avatar
Yeah it can get old when you compare it to a T56 on the street.. but i cant see what 1st gear feels like when i actually hook up and dont have to worry about my rear end exploding
  #44
AChotrod's Avatar
My car sees very little street time. So Im not to worried about it getting annoying.
What stall are you running? Is that on spray??? My car out 60s that with the M6 NA.
As for the shim thats only for LS1s, LT1s bolt up like any other SBC does so Im good there.
Im def going with the stealth pro rachet(looks great and has good reviews), if I dont like it Ill sell it and go with something else.
Old Jun 16, 2010 | 10:00 PM
  #45
AChotrod's Avatar
I have an S60 and already busted one output shaft in the t56. If its not one thing its another.
Old Jun 17, 2010 | 11:14 AM
  #46
I havnt sprayed it yet, but its a 3500 in my car. It is a nitrous converter, but i didnt expect to suck this much lol. I dont know if im even going to bother spraying it before I yank it out. I was out 60ft it when my car was a 6spd with just bolt ons, so needless to say its kinda aggrivating. But thats what happens when you dont havethe right combo.
Old Jun 17, 2010 | 12:58 PM
  #47
AChotrod's Avatar
Ya Id be pretty pissed if this back fires on me, so might as well do it right.
Old Jun 17, 2010 | 01:59 PM
  #48
Ill probably be calling FTI up, they seem to get it close to right the first time.
Old Jun 18, 2010 | 11:13 PM
  #49
robsquikz28's Avatar
4000 stall circle D
RACECAR cough cough
Old Jun 20, 2010 | 01:45 PM
  #50
AChotrod's Avatar
Im looking into Circle D a lot.
Picked up the trans, stripped and cleaned it all up then painted it. Looking good so far!!
Old Jun 20, 2010 | 01:56 PM
  #51
sidewayz28's Avatar
thats the truth right there.
Tranny looks nice, is that an Ultra Bell?
Old Jun 20, 2010 | 02:18 PM
  #52
AChotrod's Avatar
Yup, sure is! Thanks!
Old Jun 20, 2010 | 04:59 PM
  #53
Racecar, must be Nice MIke lol
Whens it gonna be done?
Old Jun 21, 2010 | 11:21 AM
  #54
AChotrod's Avatar
Hope to have it done within a few weeks. Still gathering parts and the install should be easy.
Old Jun 21, 2010 | 07:16 PM
  #55
AChotrod's Avatar
Just ordered this shifter for it.
http://www.jegs.com/i/B-M/130/81120/...75#moreDetails
Old Jun 21, 2010 | 09:53 PM
  #56
AChotrod's Avatar
So since my car is tuned for 4.10s and a factory Ws6 car has close to 26" tires do I just wire into the abs for a VSS signal and Ill be really close?
Old Jun 22, 2010 | 10:38 AM
  #57
sweetbmxrider's Avatar
that shifter is nice
Old Jun 24, 2010 | 05:39 PM
  #58
insomniac21772's Avatar
Yeah I have the pro-ratchet on a turbo350 in my mazda, works really nice. C
By no means am I trying to hijack but I wanted to throw a question out there.
If I have a ratchet shifter which i pull back to change gears, do I have a reverse manuel valve body or is it a automatic? sry noob question i know
Old Jun 24, 2010 | 05:42 PM
  #59
sidewayz28's Avatar
RMVB fo sho'
Old Jun 24, 2010 | 09:28 PM
  #60
AChotrod's Avatar
I think Im going with a Neil Chance converter possibly PTC
