i need cam choice help
So my question is what do you guys think would be the best cam for my setup. Im looking to make good N/A power and still make good power on the bottle. Ive looked at the MS3 and MS4 cams, the "el torro" cam, and a few more but i dont know whats the best bang for the buck. So please help me make my decision because im sure most of you know cam only setups better than i do. Thanks, Matt.
we are finishing up a car right now that is getting a 231/237 585/598 112lsa. this is a custom grind that speed inc speced. this is supposed to be about the biggest you can go without ptv issues. it is a good n/a cam, and i think it would make a good spray cam too.
You DO sacrifice some low end for the high end. IF you do not care about that on the street, then your ready to step up.
FYI, you should at this point fly cut the pistions to give you needed clearence and consider having the heads milled to bump the Compression Ratio, this will help with cams and ported head step ups immensely.
Either way the bump in C/R helps N/A power and Nitrous set ups.
The onlyy thing that I would consider is getting rid of the Fuddle and putting in a decent TQ converter that is made for Nitrous. I did not see the gearing mentioned but 3.73's at minimum.
http://www.engpwrsys.com/index.php?a...d&productId=10
Its what I have and like it..does what I wanted for the car!!
Best bet is to give Geoff @ EPS a call. There's a reason some of the fastest N/A cars are using his cams.
Now saying this Im going to get burned but I dont care..I know there are faster people out there but I just was letting a guy know...LS6 Heads MS4 Cam will run good..11s easy..As are a lot of other Cams but I have it so suggested it!
