Drag Racing Tech
HELP wolfe 8 pt.
Old Jul 20, 2010 | 08:23 PM
rggbly's Avatar
Default HELP wolfe 8 pt.
i found some useful threads before but cant seem to get the answers im looking for again. search keeps showing anti roll bar installs so..
1) isn't there a way to install the main hoop below the floor pans for a stronger core?
2) how do i know where things are supposed to line up at considering the cage comes with no dimensions for measurements for proper placement..
3) what all has to be done in order to weld the plates on the flat area or do you just simply weld them when in place?
and more questions will arise im sure. but i have the 8 point..no swing outs..mild steel..bars go to flat area
Old Jul 21, 2010 | 12:07 AM
droksformula's Avatar
As for question (3), you need to drop the gastank before you start welding because the tank sits right underneath I believe.
Old Jul 21, 2010 | 09:08 AM
rggbly's Avatar
alright i'll check that out. hopefully i can get some more answers cause riding around with no interior is killing me
Old Jul 21, 2010 | 10:46 AM
1320's Avatar
Im not familair with the product, but why in the world wouuldnt it go to the rear sub frame rails? Easy to get to, no removing the gas tank, and when you look in the rear view mirror, you see no bars.....clear vision.
Oh and since they are to the sub frame rails, well they are a weee bit more effective then welded to a piece off tin above the tank. Seems like the last place to weld a cage would be to the area I can cut with a cheap air nibbler.....versus the sub frame.
Old Jul 21, 2010 | 03:57 PM
subhumanzz's Avatar
unless your sig is way out of date im not sure why you are putting a bar in the car to begin with?
Old Jul 21, 2010 | 09:01 PM
fuel's Avatar
dont forget.........to move the gas lines under the drivers feet area.behind the front wheel.
Old Jul 21, 2010 | 09:30 PM
koolrayz's Avatar
look at my photobucket account in the page 19 to 21 area. there are quite a few pictures.
http://s212.photobucket.com/albums/c...ayz/?start=400
Old Jul 22, 2010 | 12:44 AM
RamAir95TA's Avatar
A good welder doesn't need to drop the tank.
Old Jul 22, 2010 | 08:38 AM
rggbly's Avatar
alright i'll check that out..is there a way to put a blanket b/t the gas lines and the floor pan? or do they need to be disconnected and dropped? also if they must be disconnected..where is this done?
Old Jul 22, 2010 | 08:41 AM
rggbly's Avatar
thanks for the help man. really appreciate it. so for the main bar..am i just trying to get it close to the hump which would be the front of the back seats? then the rest is jig notched so just line it up, mark it and tack? and i'm going to use your idea of plating up the side of the pan too..seems like it adds some strength.
Old Jul 22, 2010 | 10:47 AM
koolrayz's Avatar
I used magnets and the 2" wide green body masking tape to hold everything in place while I figured out where I wanted the bars to be mounted to the floor. Then I welded all the plates down.
I also had to take about 1/2" off the bars that go by your arms and the one behind the seat.
Old Jul 22, 2010 | 01:09 PM
rggbly's Avatar
is there no designated place for the bars to go? cause i figured the main hoop should be in a certain place for the door panel clearance for the door bars
Old Jul 22, 2010 | 01:27 PM
sweetbmxrider's Avatar
just put it in loose and make slight tweaks till it lines up the way you want. the main hoop should be just about even with the door opening. use a tape measure to verify what you think you see in terms of alignment and make sure both sides are equal. i'd tack the rear bars to the hoop first so you can lean it back and weld it the whole way round.
Old Jul 22, 2010 | 03:26 PM
rggbly's Avatar
when i get the main hoop and rear bars in place i can tack that..then take it out of the car, correct? that way after i have everything else marked off i can take it out and get good 360* welds in that area..then paint..reinstall..and weld to plates then weld in door bars and paint. sound about right?
Old Jul 23, 2010 | 10:49 AM
pretty much. i would personally leave it in the car though so you can continue to recheck fitment since it may distort some from the heat.
Old Jul 24, 2010 | 04:24 PM
fuel's Avatar
you will see the lines under that plastic pad,the pad you lift the car with
Old Jul 25, 2010 | 11:58 AM
^^^^^^^ I'm pretty sure that pad says something like "do not jack", its only plastic, I wouldn't.
Old Jul 25, 2010 | 04:15 PM
fuel's Avatar
yes it could..........or the pads are for a lift
