New times @ 4200' above sea level
Sunday i had a new best of 11.8 @ 117 here in el paso. i could have got more out of it but decided to call it a day and have some beers. that 11.8 was on bad 60' time of 1.8 (i was on 26 x 10.5 et streets since it was a true street shootout). on that run i got greedy with the 2 step and bumped it up. the run before that i cut a 1.61 but hit the rev limiter in 3rd so i think an 11.6 might be doable. BTW Harlan the 2 step is the ****
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Nice times, was this without the nitrous. By they way were have you been getting the race gas?
I want to get a few gallons so I can crank up the timing this weekend. Are you going to go to play day at Arroyo Secco on Sunday. I will be out there. I am still on drag radials but I have actually got the car to launch straight with the addition of the low control relocation brackets.
A if I only had the money, my times would be about the same as yours. I am hoping to barely break into the 11's.
Gary
Gary
yup this was n/a. call billy grahms, he has the 103 unleaded. no, i won't be able to make it this weekend since i have to work. i am going to order some a arms, k member, rear sway bar, & some hals in a few weeks so the times should get better.
Congrats on your times and winning at the shootout!
What have you done to your car as far as the engine is concerned?
Frank
Live in Albuquerque but from El Paso.
Frank
Its basically just bolt ons, g5x2, tea stage 2 heads, & a 12 bolt with 4:30s. I am going to order Hals and the BMR k member & a arms in a couple of weeks, so that should help with 60 foots.
