Drag Racing Tech
Those of you with an Accufab 4-barrell TB
Old 09-18-2010, 04:06 PM
rickou812's Avatar
Any pics yet?
I am fabbing mine up right now and looking for options.
Old 09-18-2010, 07:54 PM
TexasVortexx's Avatar
It looks the same as the pics in the original post except the TB is turned around 180 degrees. Now i Just need to mount my WOT switch and K&N is assisting in building a one off filter for my needs
Looks like your hood wont close over yours with both plates on that super vic?
I will get a few new pics up in a bit. Car runs much stronger after removing the low profile elbow and FAST 92 tb
Old 09-18-2010, 09:32 PM
Here are some pics from tonight after a cruise.... I still need to put the cowl cover back on but I cracked the windshield pulling the passenger wiper off and need to replace it first. The last pic is with the stock WS6 hood fully closed, there is almost an inch and a half clearance.
Oh, the screw on plastic cover is homemade and seals tight enough to keep water out.
Hood fully closed, 3/4 of the throttlebody is behind the hood
Old 09-18-2010, 09:40 PM
fuel's Avatar
Old 09-18-2010, 09:50 PM
rickou812's Avatar
Was you able to turn the connector on the IAC valve or was it already that way? Mine points straight up and it annoys the hell out of me..lol
Old 09-18-2010, 11:24 PM
It came that way but if the bolt pattern is symmetrical you can unbolt it and turn it 180 degrees
Old 09-18-2010, 11:25 PM
rickou812's Avatar
They are asymmetrical, that was the first thing I tried...
Old 09-18-2010, 11:35 PM
Well it shouldn't create a problem as long as there is no interference with other parts.
Red looks good BTW
Quick Reply: Those of you with an Accufab 4-barrell TB
