Drag Racing Tech
tach signal
Old Aug 20, 2010 | 08:57 PM
subhumanzz's Avatar
Default tach signal
so i just swapped my car over to a th400 and in the process i did some weight reduction. the problem i noticed last night at the track was that the shift light was no longer working. so today i did some searching on here and come to find out the pin#10 ( white wire ) where my light is getting the signal from also is linked to the cruise control which i removed. where else can i tap into the tach signal or what would even be better is how do i remedy the situation so i can use the wire its currently connected to? it seems as if my factory tach is way off. thanks for the help.
