UMI upper control arms
But I'm thinking upper a-arms aren't really worth it for just a street/strip car that doesn't need more than a stock alignment correct?
That cash could probably be spent better elsewhere right?
Depends on what kind of driving you do will dictate what it's "worth". They are so cheap I would do them and not care.
So no need for adjustables? I'll gain the strength and mobility without the rod-ends? Why would I need adjustables for a street and strip car.
The kind of driving I plan to do is weekend tooling around town in good weather with wheels up launches at the strip.
I want good short times and for the front suspension to work and transfer weight.
Have some people do this on the cheap, what they would do is remove the stock one, weld some plate on the bottom side to box it up a little and put in Poly bushings, paint and be done with it.
Upper A Arms I associate it with a Strut Tower brace, it defintly helps with street driving when you dont have things to stiffen up the chassis. BUT when you drag race, it does nothing, and its extra weight so to take it off everytime I go to the track would get annoying.
http://www.umiperformance.com/catalo...Path=7_137_103
Not bad but I guess it depends if you need Ball Joints or Want new ball joints.
IMO the Poly end stuff is just fine for what your doing. The only thing Rod end on my car is the drag bar from UMI.
They do not have caster built in but can be adjusted to get more caster. They do have improved ball joint angle for lowered cars, something you may not benefit from.
Hope that helps!
Ryan
The car will react a good bit quicker, and more consistant with them.
Because if they're going to considerably help weight transfer off the line then I'll pop for them.
You must keep in mind thought for street driving, you get the a typical "Klack, Klack, Klack" of Rod end stuff and the more you have, the more you know it is there. I do not mind the one peice that I do have. But for the good majority of street driving on this car I think I would get annoyed.
Something to think about.
https://ls1tech.com/forums/drag-raci...-specials.html
Are you saying that some sufficiently lubricated non-adjustable poly bushings will not make the suspension work more freely than stock rubber and rod ends are the only way to go?
Well lubricated poly bushings like in our upper A-Arms would work and work better than the factory rubber bushings but not as well as rod ends. The factory bushings actually bind some on up and down movement, the are forced upward and spring back quick. Since the poly bushing upper A-Arms allow grease they would rotate much easier.
Hope that helps!
Ryan
The rod ended suspension, when you see how freely it moves compared to stock rubber mounts, will be an obvious difference.
DMH's stuff is excellent, if I had to do it again I'd buy his in a heartbeat. Don't get me wrong there's absolutely nothing wrong with the Burkhart stuff I went with, DMH just wasn't making them when I bought what I have.
Well I got them, not to mention I still have a UMI drag bar to install, their torque arm relocation, an S60 with 4.10's and ABS delete. I also just received some Strange SA's with 300 lbers.
Looking for 11's in 7-8k DA.
I'll be installing all these parts in one fell swoop in November as basically a full front suspension rebuild and upgrade. I should get back close to the weight the S60 will be adding. I'll post this build up later on when I get to it.
I love UMI
