Front inner fender pics?
This will keep rocks and whatnot out of the door jamb's and stop the bottom corner of the doors from getting cracked from a rock getting in there, you not knowing it and then you open the door, and whamo, bottom corner of the door is broken off.
The inner liners are easy to cut with a dremel or cutoff wheel, and you really just need the back portion of them, probably a lb total worth of plastic if that. I am goin to cut mine and reinstall in this fashon, I'll try to get some pic's when I do it and post them up.
Here are some pics I tried to take.
Door hinges
Strut tower
and dosnt it block water for the alt. i think i remeber i took them out, but noticed it looked like it would get the alt soaked and put them back in. i drive all the time in the rain
Here is the alt water deflector.
And as you can see there is only a splash deflector to direct water away from the alt, but not 100% effective as you can see by how dirty it is.
The red bird (the second pics I posted) is all stock in that department.
Yeah I'm lucky enough to have 2 cars.
