How effective is a drag bar???
My buddy runs a slick everywhere and has been pulled over 3 times and they never say anything...they are more worried about how loud the car is...
Yes they need to pitched towards the rear at least 2 degrees.
Also - I do have a Drag Bar. I purchased the one from Spohn. It's heavy, but I like the fact you can pretty bolt it on and then weld it to the factory frame.
Any thoughts or advise????
Back to this thread.... I'm also considering a slick just b/c the consistency. I can hook on my DR, but only if the track is really there. My second NOS pass I spun. Have you tried to tighten your front shocks?
And I like my Sphon Pro series drag bar (no clearance issues)....however, I'm not that impressed with there CS. You have to play question relay with them via the operator.
Thanks!!! - Jim
Double are high, but I'm sure very nice and maybe confusing sometimes. My pinion angle is at neg 3 and mine is also an auto T350. What are your shock settings? And it TB - Turbo?
Thanks!!! - Jim
would help you hit the tires really hard and pull the front end up to ****** the tires. But yeah, I'd grab a couple clicks and see if you 60' picks up. I would guess that it would as long as the car still hooks. Do you always use the TB? I'm just wondering how you car 60's off the foot brake. And like you, I like running the fairly impressive # on a DR!!
As for the dragbar, I think most peps are making huge improvements when they are coming from 1.8/1.9 60's down to 1.6. My car leaves strait now, but not a huge improvement so speak up. But then again, I didn't have mine on my old rear, so I swapped to a 12 bold and got the dragbar at the same time. You do set the pre-load, but that's more to make the car track strait during the launch. The directions are pretty clear on how to do that both from Spohn and UMI from another thread I saw.
Wish I would have added a TB upfront... too much cake and a lot of work to add it after the fact!!
