Drag Racing Tech
custom engine mounting?
Old Oct 28, 2010 | 06:24 AM
camaro383's Avatar
Default custom engine mounting?
Hi, I wanted to know what the proper method would be to figure out the driveline angles, for example, where would i measure the engine as apposed to the car body and how could the angles and height of drivetrain affect the car or wear on driveshaft u-joints..
thanks
Old Oct 28, 2010 | 07:40 AM
tektrans's Avatar
I'm leaving that to my chassis guy but Rosslers website has this on it.
http://www.rosslertrans.com/Pinion%20angle.htm
Old Oct 28, 2010 | 12:32 PM
camaro383's Avatar
Ok, that sounds like a good way to set my pinion angle, i guess thats better than doing it based off the driveshaft??
Old Oct 28, 2010 | 03:21 PM
tee-boy's Avatar
Isn't the crank, transmission input, transmission output, driveshaft, rear pinion yoke all supposed to be in line under accelleration?
I thought that is why we set PA at -2 for stock suspension at rest.
