Drag Racing Tech
DIY ABS delete kit??
Old Nov 12, 2010 | 12:09 AM
airfix's Avatar
Originally Posted by sweetbmxrider
I'm sorry but that looks like hammered dog ****.
Old Nov 12, 2010 | 10:33 AM
sweetbmxrider's Avatar
Originally Posted by JL ws-6
Careful with that becuase it's technicially not legal.. it puts the brake line in the path of destruction, should the flywheel/flexplate ever come apart.
I think there's a rule about that, somewhere in the nhra book. I'll have to look and see, there was a reason I didn't do that myself. I did, have the line run along the bottom of the radiator support before I put teh k member in my car, but now that the entire nose is getting cut off I re-routed it along the k member. That, and the K member had some convenient tabs on it that worked out great for installing the -3an fittings in.
yeah I was thinking of going the path of the rad support when I did mine. I like your idea of the rear lines though so the calipers only need to be removed to drop the rear. I think I will be doing that
Old Nov 12, 2010 | 02:57 PM
JL ws-6's Avatar
Race your car!
Yeah, there's a support by the gas tank that makes for a nice place to run the line along.... I will admit I got that idea from billingsley's old green camaro I didn't come up with that. But, it does work out nice.
I will run the front brake line on the k member for now, but if I have to remove that for any reason once the car's done I will re-rout it along one of the tubes in the nose to the other side for ease of dis-assembly.
