Drag Racing Tech
Alternator-only bracket?
Old Feb 3, 2004 | 11:49 AM
Camaroholic's Avatar
Default Alternator-only bracket?
Anybody sell a bracket & belt combo so that I can just run an alternator off the crank pulley, and a really short belt, without the tensioner / waterpump / etc pullies being involved? I've got an EWP and manual rack. Haven't seen one of those for sale around here, but have seen a few 'custom' units in pictures here and there.
Old Feb 3, 2004 | 12:41 PM
GeorgeC's Avatar
AFAIK, nobody sells a "bolt-on" solution, but it's easy enough to modify the alternator bracket so that the alternator will pivot a bit to adjust belt tension.
That's what I had on my car and it worked fine, even @ 7000+rpms. Sorry, I don't have any pictures of that old setup.
Old Feb 3, 2004 | 04:17 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Andrew,
Give Madman a Call!!!!!!
Coach
Old Feb 4, 2004 | 05:12 AM
AL SS590 M6's Avatar
I was going to ask this same question. I had thought about fabbing a tensioner maybe.
Old Feb 4, 2004 | 08:15 AM
Tom the roofer's Avatar
There is a pic on my web page but I use the stock tensioner pully.
Tom
Old Feb 4, 2004 | 11:49 AM
Hey Tom,
Do you have any details on how you did that, or is it pretty much 'grab some bolts and wing-it' kind of mod?
Thanks!
Old Feb 5, 2004 | 08:23 AM
Talking
Originally Posted by Camaroholic
Hey Tom,
Thanks!
LOL exactly. Here is a small write up.
I have the race only also. I fought with the altenator for a day or so and then found the solution. The altenator and altenator bracket stays in the stock location. I installed the tensioner pully in the idler pully location located on the altenator bracket. The altenator bracket needs to be modified a little to achieve this which means grind off some of the bracket support in that location. You'll see. You will use only 1 bolt to bolt on the tensioner pully. The tension from the belt will hold the pully in place. The belt size is 37". You will also need to grind off a portion of the lower bolt head so the belt does not rub. That's it. It works great. I'll e-mail you a pic if you are interested. This mod works great.
Tom
Old Feb 6, 2004 | 12:03 PM
FSTR-THANU's Avatar
Outlaw 10.5 Director
Send me a pic please. I am curious to see how you idea came out.
Thanks!
Tom
Old Feb 6, 2004 | 12:17 PM
Thanks!
Tom
Please send me a pic too. agf2@voyager.net
Old Feb 6, 2004 | 01:20 PM
The pic is on his web site at:
http://www.angelfire.com/pa4/tomther...er_pully_1.jpg
Looks like he just kind of flipped it around, put one bolt through it, and let tension hold the idler's bracket against the alternator's bracket. Good idea. I might try it before the SBSO gets here.
Does it bounce around much? I have a Katech idler right now, and since it's bolt-set, it doesn't bounce at all.
-Andrew
Old Feb 6, 2004 | 08:08 PM
I don't use an idler. It is the stock tensioner bolted into the idler bolt hole and yes the tension from the belt holds it in place.
I dont believe it bounces. The belt doesn't come off and I shift at 7400 and I have shifted higher.
