Wheel Alignment
If you are on skinnies then camber won't play a role. But if you are on big rubber up front and only drag race the car then some negative camber will allow you ride the inside of the tire and not have all the rolling resistance. Minimal street use wouldn't hurt you because of the 0 tow you won't wear the tires much at all.
Caster, as much as possible, and make sure when the car is close to the bottom of the downtravel the tires are close to 0 camber.
