Is it worth staying stick for drag?
But, once you get it figured out it will work... just sucks that you have to destroy the 2500 dollar clutch before ya get it right. I know about a 1/2 dozen peple that have gone to that style clutch (not f body guys) and they all told me the same thing, buy 3 because the first one you will kill before you get it right, the 2nd one you'll have it right at the end of it's life, and the 3rd one will actually work and get some life out of it.
That was enough to keep me away from it. I was ready to pull the trigger on a used liberty I found... just can't justify the headaches for the tenth or 2 that you will get over a powerglide, after you destroy 5 grand worth of clutches.
I think we'll see 4 tenths over the auto when we get it right.
I like this combo alot. It is expensive and definately has it's learning curve.
The clutches are rebuildable at less then 1/2 the original cost of a new one.
I agree that it has its headaches. I bring a full bottle of Advil to the track...
I think the first set lasted about 10 passes and that was it LOL. 2nd one the car started to come around a little better, about the last 3 passes were decent. The first 2, pretty mugh the entire friction plate turned into clutch dust. He's now got a cooling fan he hooks up force a bunch of air at it, and that's helping with the consistancey, certainly makes it alot more livable to get under there after that's blasted a bunch of air on it to make an adjustment.
Overall he's still scratching his head, and wondering if the glide would have been a better deal and maybe he should have spend the $ on a gear drive instead to try to make more power... he's aiming to get fast enough to run the 8.50 index stuff too, fwiw.
You guys will get it, but it's not easy that's for sure.
Did you ever have an auto in Barry's car after you put the solid roller stuff on it or are you basing the fact that's running faster now then it did in your car? I just wonder how much of that is the better valvetrain and added power from the solid roller compared to when you were running it. I'm sure that the tranny is more effecient there's no question about that. Just wonder how much of what you've seen so far is what.
The solid was put in for the higher RPM's he'll be at on spray. When he tried spraying it earlier this summer one night, the RPM's were way to much for that hydraulic setup and that was with one stage.
In the summer with a +3000 DA, he went 9.86 with the hydraulic and came back about two weeks later with the solid and duplicated that same # with another 9.86.
The fall air helped it to a 9.62, but the clutch is worn out due to our lack of experience with it.
Car weight is about the same as my car was.
It's definately not a perfect comparison, but this car will easily be 4 tenths faster N/A then I was. Of course, Barry doesn't let me forget it also...
I'm surprised the solid roller didn't help the power out any. You either had a really big hyd. cam in it, or didn't go crazy with the solid one...
Regardless it's a somewhat accurate comparison, your cars are close weight wise, ya run at the same tracks, and when it duplicates the hyd performance after the solid stuff went in that's enough to say it didn't make a big difference.
You'll get that clutch thing figured out. Worst part will be the constant adjustment to keep the air gap the same as it wears.
I'm gonna be totally honest I am pussing out on putting a liberty in my sled. I wanted to do it.. but I just don't have the time to work on it as much as I would have to in order to race it for a season with one of those in there. Just too much work to get it running right. The time it will take to get that figured out I could have the car running at 95% by the time I just figure the clutch part out... and I'd rather spend the time racing it during the season and spend the offseason working on it.
The solid we installed is a specific nitrous grind with no inentions of running the car N/A. It is basically no bigger then the hydraulic with he exception of more exhaust duration for the nitrous. Our lack of knowledge with this clutch has forced us into running it N/A so we don't blow this thing up.
To me, automatics are just boring. Auto's are consistent yes, but if I'm not having fun then what's the point? I'd have more fun shifting/driving a slow stick car down the track than hit the gas/steer a faster auto car, but that's just me.
To the OP, good luck with your decision.
Mike
