Drag Racing Tech
drop spindle
Old Nov 29, 2010 | 10:51 AM
tee-boy's Avatar
Default drop spindle
what's purpose of running the drop? Is it to make up for difference in ride height due to less weight on the nose? Suspension geometry?
Old Nov 29, 2010 | 01:39 PM
5.3LJimmy's Avatar
I'm not sure what the reasoning is behind it. I have the Racecraft spindles on my car and it actually acts like travel limiters. I had to crank the adj shocks up alot to get my car where I can load it on the trailer and the shocks are almost fully extended. I wish I would have seen the Burkhart spindles that allow you to keep the stock height as 2" of drop is way too much for most cars.
Old Nov 29, 2010 | 03:57 PM
tee-boy's Avatar
I'm with you. It has to change the angle on the LCA's.
Old Nov 29, 2010 | 04:03 PM
Steve Burger's Avatar
LS1TECH Sponsor
They will allow you to lower the car and maintain the stock suspension geometry. That's the short answer.
Have you seen a car that has been lowered and the front tires sit out at the bottom? When the car was lowered it altered the suspension geometry as iff the wheel was very far up in its range of travel.
The spindles will fix this if used correctly for the drop you want.
Old Nov 29, 2010 | 04:18 PM
tee-boy's Avatar
Default fdfdfd
that's what i figured. keeps caster/camber stock when running a shorter spring.
Old Nov 29, 2010 | 04:36 PM
tee-boy's Avatar
i meant stock lenth springs.
Old Nov 30, 2010 | 08:05 AM
LS1TECH Sponsor
Yep, you are correct.
Old Nov 30, 2010 | 09:04 AM
ty_ty13's Avatar
7 Second Club
2" drop is too much for anything other than a back-halfed car. a stock suspension car can use a .5" drop spindle and that would be about right. i had burkhart build me a stock height spindle after having a 2" drop on it.
Old Nov 30, 2010 | 10:00 AM
5.3LJimmy's Avatar
There is definitely a place for a 2" spindle, but it's not needed on the majority of cars. Stock suspension cars would be better off with stock height or a 1" drop if there has been extensive weight reduction.
Old Nov 30, 2010 | 01:41 PM
LS1TECH Sponsor
I have 1.5" drop on mine but it never sees the street. Hell it's only seen the trailer for a while now. But 1.5 is about as far as I would go even on a full race car.
