Minitub vs. tire size?
I'm looking at finally minitubbing my car this winter and going bigger than the 28x10.5's.
Has anyone fit a 31.0'' x 10.5'' - 15''W in there?
Right now I'm running a 10" wheel with a 5.5BS (Rear is shortened) and it's just about flush with the quarters. I was looking at going with a 12" wheel with a 3.5BS with a 31.0'' x 10.5'' - 15''W if I can get it to fit.
Any opinions?
a 29.5 S or W will fit, with a minitub, and if you convert to coil overs, and the control arms, you will have to run the style with the bushing in the rod end either with a big bolt removing the bushing so you can shove them in as far as possible, or just make a spacer to only protrude on one side. Or, relocate the control arms inward, and put the shocks on the inside of the frame rail (coil overs)
Problem you'll run into with the 31 inch tire is the carcass width. I'm trying to pull the tires in so they are up in the fender right now, so I can really slam the car on the ground, and a 29.5W was what I wanted to start with since I can run up to a 33x10.5W in the class I want to run.... and what I am seeing, is that the control arm and spring are the first 2 trouble makers LOL.
I'm also going to put a full 44 inch tub in just so I don't have any issues with the tire hitting the factory tub... because once you start getting that big, and try to lower the car the factory outer tub is in the way too.
If you are back 1/2ing the car, you can do whatever you want... but to keep the stock suspension, you will be limited. a 315 radial fits, and you can go a little taller then that, but width wise that is pretty much the max from what it looks like to me, if you want to pull them in. If you're going to really open up the whole wheel well, I mean top, width front to back etc, you probably can do whatever you want, but that's gonna probably look pretty screwy.
