Drag Racing Tech
Pulling wires
Old Dec 5, 2010 | 08:40 PM
1mean96ss's Avatar
Default Pulling wires
Just to make sure, as long as i trace the wires back to the pcm then i should be fine to remove them completely correct ? Im trying to get rid of the air bag, stereo, speakers, abs, hvac, and some of the interior lights.
Old Dec 5, 2010 | 10:33 PM
airfix's Avatar
Correct, I plan on doing this sometime this winter aswell.
Old Dec 5, 2010 | 10:34 PM
nemss1's Avatar
as long as the wires dont run in circuit with anthing else. most of the things you are removing, run into the BCM. ABS wires run into the engine bay
Old Dec 5, 2010 | 11:08 PM
SScam68's Avatar
Yea, just make sure you're know what it is you're going to keep/need i.e. vss sensors, oil, fuel etc. They all feed into the PCM, and those feed out through the diagnostics line.
