Drag Racing Tech
Alignment issues after k-member install..
Old Jan 3, 2011 | 09:06 AM
Magnet's Avatar
Default Alignment issues after k-member install..
I just instaled a BMR k-member last week, and the alignment was aweful as expected. I brought it to get aligned today and they said they couldn't get it aligned and I need adjustable lower a-arms
He is a gearhead and didn't charge me since he couldn't get it right, but what should I do? I know there are plenty of people running stock a-arms on a tubular k-member, and I don't want to spend the coin on a-arms..
Old Jan 3, 2011 | 10:30 AM
BMR Tech's Avatar
I would recommend trying another alignment shop.....
A lot of alignment shops are thrown off if the factory alignment tool can't be used...
Our K-member actually offer a broader alignment correction window then the factory K-member.
If you are still having issues just give me a call here at the office and I am sure we can figure out the issue.
Old Jan 3, 2011 | 10:32 AM
Magnet's Avatar
Sounds good, thanks! For the record, the k-member fit beautifully, and by no means am I blaming the issue on it
Old Jan 3, 2011 | 11:25 AM
slow67's Avatar
Gingervitis Addict
Theres a reason for the slots where the a arms bolt up.....
Old Jan 3, 2011 | 11:40 AM
Magnet's Avatar
Theres a reason I ask questions.. I'm a noob. I'm goin to have to take another look to see if there's movement in the slots left
Old Jan 3, 2011 | 07:05 PM
1mean96ss's Avatar
prybar on the backside of the lower control arm, just like a trailblazer adjustment.
Old Jan 3, 2011 | 07:26 PM
studderin's Avatar
thats weird? I took some measurements before I took the rack, and arms off my stock Kmeber, And the lower arms have like 1/4 more room in and out of the rear mount. did you put diffrent spindles or upper shock mounts or somthing?
Old Jan 3, 2011 | 08:17 PM
Magnet's Avatar
Nope, everything is stock other than the k-member. You can visually see my driverside tire is crooked by 1-2 inches while the drivers is straight.. I'm going to try and play with it tomorrow and get it at least visually straight and then bring it to an alignment shop..
The guy who was doing the original alignment is building a turbo 5.3 in an rx7, so I figured he would know what he was doing..
Old Jan 4, 2011 | 09:26 AM
Magnet's Avatar
Looked at it last night, and the passenger wheel is visibly pointing out, but the front slot of the a-arm is moved all the way in. My thoughts are to move the whole k-member slightly towards the drivers side, you can see the bolts are sitting on the drivers side of the mounts, as well as move the rear of the a-arm out to straighten the wheel.
Thoughts?
All I want to do is get it close enough for a shop to do a real alignment..
Old Jan 4, 2011 | 12:11 PM
Magnet's Avatar
Having issues guys, can't figure out what doing on to make it so far out... did my best with the pics. These pictures are with the steering wheel straight, or atleast what I think is straight unless I messed up the linkage?
Drivers side
[IMG][/IMG]
Passenger side
You can see that the k-member could be slid toward the drivers side, but is that really the issue?
Old Jan 4, 2011 | 02:21 PM
5.3LJimmy's Avatar
I can see why the alignment shop couldn't get it right. That thing has a helluva lot of positive toe! I don't think moving the k-member or the lower control arms is going to fix that. Are you still using your original factory rack and pinion?
Old Jan 4, 2011 | 02:27 PM
Magnet's Avatar
Yep, everything completely stock other than kmember, and it all worked a week ago on the stock kmember.
I talked to Kyle at BMR and he seemed like a great guy and was helpful. He even got on ls1tech to look at the pictures I posted I'm currently at a different (presumably better) alignment shop and they said they can do it
I'll let you guys know how it goes, thanks for all the help!
Old Jan 4, 2011 | 02:31 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
That's good news, if you run into anything give me a call at the shop.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jan 4, 2011 | 02:50 PM
5.3LJimmy's Avatar
Good luck with the new shop! Hopefully you have enough adjustment for them to straighten it out.
Old Jan 4, 2011 | 03:02 PM
johnzss's Avatar
I have a BMR kmember with stock lower, upper arms. After install my alignment was shot. Took it to the shop and everything is perfect. Like what everyone else said, find a better shop. GL!
Old Jan 4, 2011 | 03:21 PM
Magnet's Avatar
New shop did an awesome job and its drives like a dream now!!
The guy was an old racer who used to run pro stock back in the day, and he's building a 66 'Vette with an LS1 and C4 suspension
Thanks for all the help guys!
Old Jan 4, 2011 | 05:01 PM
studderin's Avatar
cool, looked like you had to make some changes with the outer tierods, then the control arm to change the toe
Old Jan 4, 2011 | 05:16 PM
Magnet's Avatar
Yea it was pretty off, I didn't expect to have to adjust the tie rod ends though...
Doesn't make a difference to me though as long as it goes straight
Old Jan 5, 2011 | 09:05 AM
BMR Sales2's Avatar
Glad you got her going in a straight line!
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jan 5, 2011 | 09:20 AM
ISMELLRICE's Avatar
sweet! glad its fixed this will be one of my future mods...gotta get my ls6 intake first :/
