Drag Racing Tech
Kirkey Seats
Old Jan 7, 2011 | 09:55 AM
mr_biscuitz's Avatar
post up some pics when you get them in
Old Jan 9, 2011 | 10:48 AM
DopeFedZ's Avatar
I have Pro Drags in mine. I have about 15000 miles worth of seat time and have no complaints or regrets about putting them in the car. Im using the racecraft brackets with them.
Old Jan 9, 2011 | 12:32 PM
Nsty98LS1's Avatar
Carlos, what steering wheel is that?
Old Jan 9, 2011 | 01:36 PM
Magnet's Avatar
Hey how are they without bein mounted to a roll bar? I was always told this was a bad idea bc 1. It doesn't pass tech (if there strict) 2. The seats aren't sturdy enough..
Old Jan 9, 2011 | 01:40 PM
joelster's Avatar
Who told you they aren't sturdy? I run them and had them installed about 3 years ago. I ran them without a cage for 2 years, and they were fine. No flex or anything. I used the bottom-half of the stock seat mount and mounted the seats (with Kirkey brackets) to that. Zero issues so far. I'm 6'2" and can put my helmet on inside the car with no problem.
Old Jan 9, 2011 | 02:07 PM
robsquikz28's Avatar
They should be braced to a rollbar of some sort BUT they do not need to be...Many people have them in cars without them.
Old Jan 9, 2011 | 02:21 PM
studderin's Avatar
Im sure there fine untill you crash the car and they really hurt you.
Old Jan 9, 2011 | 02:25 PM
yep, thats the only time it matters!!!
Old Jan 9, 2011 | 03:15 PM
94FBIRD's Avatar
What do the Kirkeys weigh with the Racecraft brackets?
Old Jan 9, 2011 | 05:05 PM
joelster's Avatar
How so? The only weakness I see with a car that has Kirkeys and no cage, would be for that car to be rear-ended HARD. Then I could see it MAYBE folding back since it would only be bolted to the floor. A front end collision would be no different than if a stock seat were in place, the seatbelt does the stopping. I've never seen a broken Kirkey seat. Not saying that it hasn't happened, I just have never seen one.
Old Jan 9, 2011 | 05:57 PM
studderin's Avatar
stock is stock, race is race
the stock seatbelt in a kirkey, is not going to hold your tight IN the seat like the stock belt dose for the stock seat for a front end hit, like the way carlos has it.
The lap belt is gona be loose and not fitting you TIGHT in seat right. With it going over the leg bolster. In a hit your hips are going to move up out the the seat with tons of force, untill your hips hit the stock belt. Thats could break your hip and legs. You need to stay tight in the seat. And the stock belt it will probally bend the kirkey leg bolsters into your body, hurting you more. Or making you trapped into the bent seat hurting you more. Running the lap belt thu the holes in the seat would be better but still not right.
take 175# in that seat, and have it go 60-0 instantly, that seat is gona bend to ****. Even 130 on a race track, I don't know the specs but you can get 5-8 Gs I've been is some bad head ons, like motor nocked out the the car, trans broke off. and thats just a one time hit.
If you have to drive the car after the seat bends on the 1st impact, your fucked, just along for the ride. Or the car starts to roll, Your going to get fawked up in the seat with a stock belt, not fixed to a seat bar.
Old Jan 9, 2011 | 05:59 PM
  #32
Magnet's Avatar
I have seen a mount that goes from the floor to the back of the seat to support it without a roll bar, but I can't find any pics or info on it now.. I thought a sponsor carried it or something, but I'm not having any luck locating it..
Old Jan 9, 2011 | 06:04 PM
  #33
studderin's Avatar
The stock seats are made to hold some super fat 300# guy in a crash. there stronger then people think just because there stock dosn't mean there not safe. Racing seats lighter but not stock replacement seat.
The kirkeys are made to be properly fixed mounted. And but used with a 5 or 6 point harness properly mounted. No BS running the solder straps to the floor, thats will compressed your spine really bad.
safe is safe
Old Jan 9, 2011 | 11:53 PM
  #34
Magnet's Avatar
What bout something like this?
Old Jan 10, 2011 | 01:06 PM
  #35
Asian LSX's Avatar
I'm curious, how much different is the seating position height for Kirkey pro seats with Racecraft brackets? If its any lower than stock, that would make life that much harder for me since I'm your typical "small asian guy" at 5'11" 150lbs.
Old Jan 10, 2011 | 01:32 PM
  #36
DopeFedZ's Avatar
It's a brand made by Momo called Race. I don't know if is still around or not but Momo has a wheel by that name also which is the same.
Old Jan 10, 2011 | 02:17 PM
  #37
studderin's Avatar
ya I think I have what it changed into, a momo compaition (sp?) I didnt put the trim ring on just has the horn button. Also nice with the 6point and kirkeys for giving you more leg room. I drove a friends car with a wolfe, stock sterring wheel, and seats. And cruising with you left knee up, it get stuck over the door bar and the bigger stock wheel when you go to turn. Just a little thing about the slightly smaller wheel you don;t really notice. And with the m6 you can use your left knee to hold the smaller wheel to shift easier mid turn while on the phone too.
http://i2.photobucket.com/albums/y11...n/IMG_3003.jpg
http://i2.photobucket.com/albums/y11...n/IMG_3002.jpg
http://i2.photobucket.com/albums/y11...n/IMG_3276.jpg
I painted the back of my kirkeys, look a little more stock form the back, no headlight glare. But still only 1/2 wide form the side. lol never got any pics in the car.
http://i2.photobucket.com/albums/y11...n/IMG_3937.jpg
Old Jan 10, 2011 | 03:11 PM
  #38
DopeFedZ's Avatar
The painted seat looks good. I've had that on the to do list for a long time just haven't figured out if I should paint it or powdercoat it.
Old Jan 10, 2011 | 04:38 PM
  #39
Magnet's Avatar
Carlos, how are the stock seatbelts and the kirkeys? And hows the rigidity without a cage?
Old Jan 10, 2011 | 07:06 PM
  #40
sweetbmxrider's Avatar
Mine sits lower but I still see fine out the windshield. I see through about the center with the kirkey and a good 3 inches higher with the stock seat. It all depends how you mount it though.
