New build
what did you use for seal sealer?
On the area behind the tubs, you welded in sheet metal? I'm doing that now, but with panels. How thick did you use? Got any better pics of them? And from the bottom? thanks
What did you used for seal sealer?
Looks like you narrowed the driver side frame rail?
Nice work on the dash bar, I saw after I asked about it you removed the stock studs for the dash brace any way. Still going to use the middle sliver metal bracket, for the dash and console?
I see a couple more pounds, the gastank bar in post70. (your runing a fuel cell I take it?) The rear seat belt oval metal under the car, and heat sheild tabs.... that hold down tap in the middle right about the Ttop well. Have any idea what thats even for? Jolster on here looked at some of his cars for me. Its not used back to earily 4th gens for anything, on a coupe or a convertible?
Whats you hood plans? I'm really happy with the racecraft rails. They bolt on with hand tools, to the fenders, and bumper cover. You dont have to weld or make any brackets for them, and paint them. You can take the fenders and bumper off easy.
I like how you have the rear bars with a tube down to over the coils, and another going back. When I upgrade more then my 6point I'm gona have somthing like that and run the bumpstop metal out.
It really looks like you only narrowed the passenger side rail?
good stuff.
