06 LM7 Harness Generator Battery Control Module - Delete
I'm working on the harness off my 06 silverado and I've hit a small road block. I'm trying to figure out what to do with the Generator Battery Control Module. Here are some options, but with questions:
1. Keep it.
If I do end up having to use it, do I have to put it back near the battery or can I put it on the ground cable that goes from the motor to the frame? If I have to put it back near the battery then I'll have to run some additional wires back up to the front to hook back into the harness. As far as I'm concerned this is the **** option.
2. Get rid of it. Ok, how? I did a ton of searching on the forums tonight and I can't seem to find any definate answers. If I can get rid of it, how hard would it be to convert to a one wire alternator, and how do I get the factory volt gauge to work?
I did a ton of searching on the forums tonight and I can't seem to find any definative answers on deleting it. I have seen where some people take the brown and grey wire from the alternator to a switched 12v source with a resistor on one of the wires. But I can't find an answer on what to do about the rest of the wires. If I remember right, there are 7 wires that connect to the GBCM. 2 appear to be grounds (black w/white stripe), 2 feed into the under hood fuse box (red w/black stripe), 1 wire that appears to go back into the cab, possibly for the instrument cluster (orange w/black stripe) and then the brown and grey to the alternator.
My truck appears to be different than any year model before it as the research I've done shows the 05 and earlier trucks with the alt. wires going to the pcm. Mine don't.
I would appreciate some help on this, I sure its been done, I just haven't found anyone that knows how to do it.
I have a 2006 5.3, if I change to an '04 OS, can I still use the alternator I have?
I talked to some alternator shops and they can convert an ls style alternator to one-wire, so that would allow the alternator to work without being hooked to the pcm or gbcm.
I've since converted to a stand-alone harness for a 411 pcm so I can't say for sure that the remaining vehicle electronics would be happy without it using the factory 2006 wiring, but I can't help but think all would be fine by turning the related dtc's off.
I'm am going to be using a one-wire on my new setup so the alt. will not be controlled by the pcm.
i ended up eliminating the battery control module. the ECM has pinouts for both alternator connections and wire colors match. The wires originally went from the alternator to the Battery Control Module and the brown & grey wires went from the ECM to the Battery Control Module. I eliminated the BCM and simply connected the 2 wires together. after researching the function of the BCM, it appears that it only GETS info from the ECM via the data wire. The BCM uses info like, rpm, vss, tps, etc to maximize charging and fuel mileage and minimize emissions.
Blue ECM Connector
15 - Brown - Generator Turn on Signal
52 - Grey - Generator Field Duty Cycle
