Do I Need A Bigger Stall TC?
If you aren't planning spraying I would move to a 4400, if spraying stay where u are.
That should get you in the high high 1.4 range and get you some 6.9x passes.
**phone
Just going from 1.60 to 1.55 will take you from 7.25 to 7.15.
You can easily have 700+ in a nitrous kit before you know it, mostzly buying used part too. Lol
If all you really care for is all motor.. put a 4400 in, you wont be sorry. You need to get the car hooking though before anything.
My car ran 7.20@ 97mph with 1.601 60' with a cam pretty close to yours with a Fuddle racing 3600 nitrous converter. I got the car to run 6.90's N/A with 1.47-1.49 60' and do you know how?
I'll start by saying I never touched the converter, I bought adjustable drag shocks all the way around and some half decent adjustable suspension parts and tweaked the suspension until I dialed in the 60'. I would highly recommending putting your money into adjustable suspension and especially some good shocks and get the most out of your setup before you go changing things that may not necessarily be the issue.
I would approach the car in this order: maximize suspension setup, lower the gear ratio, then up the converter stall speed. I wouldn't recommend running a 4000+ stall speed with less than a 3.90 gear ratio. The motor will get "up on the converter" and lag there until the wheel speed catches up.
I would look at suspension... then either converter or nitrous.
