Drag Racing Tech
PSCA Limited Street engine build
Old Jan 25, 2011 | 08:18 AM
Shawn @ VA Speed's Avatar
Default PSCA Limited Street engine build
http://www.dragzine.com/project-cars...irginia-speed/
Old Jan 25, 2011 | 07:02 PM
fuel's Avatar
its cool to see what you look like shawn....good luck
Old Jan 25, 2011 | 08:39 PM
Broke EF's Avatar
I thought he looked like Kid Rock?!
Sean
Old Jan 26, 2011 | 07:34 PM
Sean
If you would have seen me 15 years ago- that would be pretty accurate
Old Jan 26, 2011 | 10:08 PM
Phil99vette's Avatar
7 Second Club
Sean
If you are referring to my kid rock comment from a week ago, he doesn't look like kid rock but he drives a car that Kid rock would be proud of.....
Old Jan 27, 2011 | 02:28 PM
Fireball's Avatar
Shawn the rock star
Old Jan 27, 2011 | 03:51 PM
WKMCD's Avatar
It's always great to be acknowledged.
The secret's getting out...
Old Jan 31, 2011 | 03:23 PM
silver2010's Avatar
Well i was at VA. SPEED on thursday checking on my build and the SuperStar walked by and i tried to get his autograph to no avail. DARNIT!
Old Feb 2, 2011 | 08:47 PM
Ken,you know i can't write!
Old Feb 3, 2011 | 07:56 AM
JL ws-6's Avatar
Race your car!
With the power goals that the article mentions... how much easier would it be to reach those goals with a bigger blower, say an f2 or f1r, gear driven?
Have you done anything with a centri supercharger and a blow thru carb? Curious on your thoughts.... (blow thru, and meth if needed instead of ic for weight/packaging reasons)
Old Feb 3, 2011 | 02:46 PM
vettewrench's Avatar
I have a few autographed pictures ( glossy 8/10) will go to the highest bidder .
Old Feb 12, 2011 | 07:52 AM
WKMCD's Avatar
No signature but I do have these..
Old Feb 14, 2011 | 12:39 AM
ericg69ss's Avatar
The class will not allow it. Biggest blower you can run in PSCA Limited Street is a F1C.
Old Feb 14, 2011 | 02:40 AM
kmracer's Avatar
im sot sure what they were thinking, they should have just bought an lsx454 and been done with it. THE BLOCK IS GOOD TO 2500 HP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1111111111!!!!!!!!!ONE!
Old Feb 14, 2011 | 08:24 AM
JL ws-6's Avatar
Race your car!
I know the class won't allow it.. but the goals put forth for this build are about in line with where I need to be.. and I don't have any limitations to what I can do.
Old Feb 14, 2011 | 05:20 PM
COOKIE MONSTER's Avatar
Congrats Shawn! Say, who's beautiful pewter TA is that in the background?
Old Feb 14, 2011 | 07:22 PM
caught that huh,thanks
Old Feb 14, 2011 | 07:27 PM
it will always be easier to make more power with a bigger blower. We are going to test this engine with a f1r for possible 275 racing.
Old Feb 15, 2011 | 09:20 AM
JL ws-6's Avatar
Race your car!
Please post the results. I'm interested to see what it does with the larger blower. I have no limit with the size for 8.50 index stuff, so I can do pretty much anything.
The 408 I have sitting here, is a 4 bolt motor, but with the ET 4 inch bore ls7 heads... I know that with a 6 bolt conversion, and on something that's somewhat smallish , around the 400 inch # an F2 should be about the right size to be able to make some good steam. I know about 1/2 the motor will be good parts (all brand new), shortblock will have to go, but that's a livable scenario.
I'm looking a a couple differnt possible blower drive setups, all of which should be reliable, and it's either cog driven, or a gear drive.
I really want to do the blow thru carb with this next setup and run a GM distributor setup and a digital 7 box... If it's a must due to iat's I'll put a meth kit on it, but for the simplicity of the plumbing, and in an effort to keep the car as close to the 2800 lb min the less plumbing and whatnot I have.. the better.
Keep the updates coming... very interested to see what happens.
Old Feb 15, 2011 | 08:25 PM
you need to forget about the blowthru carb. There has never been a car with a blow thru that has run a quick as it should.
