Whats your 2011 Goals..
#45
To run some 10's with a full weight stock suspension daily driver and get kicked off our track for no roll cage (11.49 or faster). I also hope to have no clutch problems this year, going to the track to have the pedal stick to the floor pisses me the F off! The new altitude compensator should really help
#54
Mine are simple in theory;
1. Win the points championship this year in N/E at Royal Purple Raceway(HRP).
2. Finally run a 9 second 1/4 mile with my N/A 347 Hot Rod(been trying for like 6 years now)!
Good luck to everyone and have a safe & winning season this year.
Coach
Coach
#57
Hmmm goals for 2011...............
Put the battery in the battery tray, hook it up and prey to God that everything works.
Once I've passed that step, I want to hook my custom engine/trans harness to the pcm and see (if) the motor will run like its supposed to without any electrical glitches.
I've pretty much done a hack job on this wiring and told my friend that if this thing works everyone is coming over for a drink........
After that the goal is getting a bored 5.3 block with stock 706 heads with cometics and arp bolts to hold up to an F2 procharger with a cog drive spinning out about 25-30 psi.
My year has the makings of a pretty epic fail. We will see.
#58
To get my **** running again Fortunately, it's the wife putting the fire under my ***!!
Goals for 2011: Hit the 11 second goal I set in 2007 with a bolt on car at 8000ft DA.
Stretch goal: Cut the last 200lbs of dead weight from the car with drag brakes, lexan, manual brakes and manual steering. Be down to 200lbs by track time and also participate in my first triathlon.
