Tubes vs No Tubes
However the trick does work, I guess you just have to weigh your options. For me it was the best option at the time and until they start slipping I will stick with the High Tack.
If you can get away without the screws then I wouldn't use a tube.
But, I went dbl beadlock, so now I have the benefit of screws, without the headache of having to deal with them.. I'm going to try it without the tubes, if they don't leak, then I won't run tubes. If they leak at all, tubes are going right in there.
For the OP I'd reccommend tubes for him, since the weight of the car is up there, and the tube will make the tire act like it's stiffer. He will have to screw the rim, because you can't run a tube without a dbl beadlock, or screws... the tire moves on the rim it will rip off the valvestep, cause the tire to go flat, possibly wrecking the car like mentioned above, etc.
Tire slips on rim, put screws in, tires leak like a ****. Happens with every type of rim and tire it seems, and it doesn't make a hoot of difference what kind of screw or length you use.... just is what it is.
Tubes with screws, maybe with beadlocks, that's all there is to it.
My experience with these things is real world, not 2nd hand, not my cousin's brother's uncle's, 3rd nephew's next door neibhor type ****.
My car has 26x11.5x15 MT ET Streets (Bias of course) - no tubes. I typically run 14-15psi on them and dead hook with shitty high 1.6 low 1.7 60's. All my videos show I'm murdering the sidewall.
If I switch to a 26x10 or 28x10 stiff sidewall MT slick would I still kill the sidewall without a tube? I really don't want to drill my wheels for screws. If I went 28" it'd get 4.56's as well.
I know the issue you're having, been there with that tire, know all about it. The sidewall's are really soft, you really almost have to have a tube with them.
I couldn't get the 15x12 with anything more then a 5 inch backspace... so the things stick out about 5 inches LOL. rear's gonna get narrowed 6 inches per side, shocks, control arms, phb, all getting shifted inward at the same time to do that too.
A 15x10 I think you can get a 5 inch backspace with too, but that's still gonna require at least a 2.75 inch cut on the axle to get the thing inward enough so the tire's aren't chico style out of the wheel well.
Wonder If they would work fine for a slower M6 car. Sorry for the Hi jack OP I also heard how much those wheels weigh.. #'s I have heard were about 40% heavier then what the other brands are....
wonder how much $$ to beadlock my street lites
