Difference in solid vs hyd roller
If you decide an auto swap suites you, then go solid roller.
I do not know or care about street racing, but at the track the hydraulic roller help create a tq band you need to get the most out of your launches in a stick car. Again, if you go auto then go solid roller w/ a big stall
You might be right on the second part of your statement, I am not sure. But again, it defeats what the OP suggested.
If you are pulling more RPM then, yes you may need to gear it steeper. However, depending on how much faster you are going to trap, you may not be able to gear it steeper UNLESS you are ok with letting off the throttle before crossing the line. Use online calculators, u will see what I am talking about.
In regards to your last comment, you have to be kidding me? We are talking about a STREET driven f-body here. A pro stocker doesn't drive his car 3-5k miles a year does he? No. Ask one how often they replace or adjust their clutch.
But by all means, you know it all. How is your t-56 solid roller working out for you? Or the next guy's?....
that was a great laugh, seriously.
