Drag Racing Tech
Car hauler?
Old Feb 27, 2011 | 06:33 PM
hawk584's Avatar
Default Car hauler?
i'm looking for a light weight open bed car hauler. my hawk sits pretty low to the ground. just wondering if any of you have any recommendations. my fj cruiser is rated at 5k towing
Old Feb 27, 2011 | 07:03 PM
custm2500's Avatar
Ph.D. in HUBRIS
You looking for new I would assume. 18" foot is usualy the smallest you see car haulers in, I would guess you could get slightly shorter if you custom ordered one. You are going to need something on 15" tires and make sure the deck is bellow the tires or you will never get your car on it! This trailer is one we have at work and putting my friends Caravan on it I had to lift on the fender for it not to scrape. The deck hight is around knee high and WAY too high for a low F-body.
You may want to look into aluminum if you can afford it because you car and a steel trailer is going to easily be 4000#s. Your FJ should have no issues but the lighter the better for eccomomy and less stress on the truck.
Old Feb 27, 2011 | 07:39 PM
Black 99 Bird's Avatar
Will you be pulling any mountians with the fj? And by the way most steel trailers are 1600 to 1800 lbs. and aluminum trailers are $$$.
Old Feb 27, 2011 | 08:09 PM
hawk584's Avatar
yes, i'll be pulling up and down mountains. i have the electric trailer brake system all hooked up.
Old Feb 27, 2011 | 08:57 PM
joelster's Avatar
Check out racingjunk.com and do a search on aluminum trailers. Brand new they are around $5000ish to start. They weigh around 1000-1200lbs.
http://www.racingjunk.com/category/5...r-Trailer.html
Old Feb 27, 2011 | 09:25 PM
hawk584's Avatar
thanks guys
Old Feb 27, 2011 | 09:44 PM
Dirty Vegas's Avatar
I have an aluminum Featherlite. I love it, and haven't had a single problem with it in the year I've had it. I probably put every bit of 10k miles on it last year.
Old Feb 27, 2011 | 10:15 PM
hawk584's Avatar
how much does that flatbed weight?
Old Feb 27, 2011 | 10:23 PM
Right about 1400lbs, and I don't have a problem getting my lowered Camaro on or off. Not even close to scraping even with my Chrs1313 ram air installed.
Old Feb 27, 2011 | 10:40 PM
hawk584's Avatar
that's close to 5k..... i like it though. it's good to know you don't scrape as well... do you by chance know the model number?
Old Feb 28, 2011 | 05:05 AM
slowblackbird's Avatar
i just bought a wally mo trailer for my trans am. it is a real nice trailer, as for straping the car down it has built in chains with 4 different kind of hooks witch makes straping the car down a breeze. also it has removable finders that might help if your car is real low
Old Feb 28, 2011 | 06:34 PM
HioSSilver's Avatar
I don't know where you are op but I have a Featherlite forsale. It has a winch and the big fiberglass car guard for the front.
Old Feb 28, 2011 | 08:36 PM
hawk584's Avatar
shucks... i live out in Cali. thank you though
Old Mar 1, 2011 | 10:26 AM
custm2500's Avatar
Ph.D. in HUBRIS
If you are pulling over mole hills you will not want your Growler and car to weigh more then 4000 and preferably less. Other wise you will be sitting on the side of the road quick. Your FJ isn't really ment to haul more then a lawn tractor.
Old Mar 1, 2011 | 02:11 PM
hawk584's Avatar
yeah, the fj cruiser guys highly suggested not to use the fj as well, guess i'll be asking a co-worker who has a 2500... thank you guys
Old Mar 1, 2011 | 04:32 PM
custm2500's Avatar
Ph.D. in HUBRIS
You could swap a 6.0 and a 4l80e and be ready to go!!!
