3.70's with 26" tire is = to 28" with x gears??
Guys i'm not sure if this is the right section for this but just wondering if there's a formula to figure this out. I'm looking at running a 26" tire n/a and was trying to figure out what a 3.70/26" combo is equal to gear wise with a 28" tall tire.
Thanks a bunch!
Thanks a bunch!
Internet Mechanic
http://www.csgnetwork.com/multirpmcalc.html
This does work, but your est your MPH if you do not know it already. I know there is a better one out there but I gotta search when its less busy at work.
You divide the roll out(circumference) of 28" tire by the roll out of the 26" tire and multiply the gear ratio by the result.
Ex: 28x3.1416=87.96
26x3.1416=81.68
87.96/81.68=1.077
3.70x1.077=3.98
It will take a 3.98:1 gear to keep it exactly the same. Because they may not make a 3.98 gear you choose the closest available.
Ex: 28x3.1416=87.96
26x3.1416=81.68
87.96/81.68=1.077
3.70x1.077=3.98
Ex: 28x3.1416=87.96
26x3.1416=81.68
87.96/81.68=1.077
3.70x1.077=3.98
Ex: 28x3.1416=87.96
26x3.1416=81.68
87.96/81.68=1.077
3.70x1.077=3.98
Thanks a Ton!!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
