Drag Racing Tech
SummitStars
Old Mar 9, 2011 | 09:28 AM
ParkerSS's Avatar
Question SummitStars
I know it's probably been done to death but I searched a few threads and couldn't find a straight answer.
Will the summit pro star knock offs clear stock brake calipers and rotors in a 15x4 up front and 15x8 out back with a 5.5in back spacing? Also what back spacing is needed for the front? And will I need any spacers?
Thanks guys!
Oh and what size tire would I need for the front and whats the max width Drag Radial I can run in the back?
Old Mar 9, 2011 | 10:58 AM
ParkerSS's Avatar
Anyone?
Old Mar 9, 2011 | 04:17 PM
96LT1355Z28's Avatar
They clear my stock brakes but mine are LT1 fronts, yours will be larger and probably require some grinding on the caliper. I have 15X4 with a 1.75 BS on the front and 15X8 with a 5.5 BS on the rear, if I could do it again I'd go with a 10" rear wheel though.
Old Mar 9, 2011 | 04:29 PM
ParkerSS's Avatar
Would I end up having to grind the rear?
Old Mar 9, 2011 | 06:29 PM
rob scott's Avatar
I had to grind and grind and grind and grind and grind..........and grind to get my 15x10's to fit. If I have to do it again I will just buy a better set of rims. There nice for the money though.
Old Mar 9, 2011 | 07:19 PM
ParkerSS's Avatar
Would I have to grind a lot with a 15x8?
Old Mar 9, 2011 | 07:57 PM
rob scott's Avatar
you already have the rims? If so jack the rear up and put them on and turn them. That way you can see if you have to grind alot. I put mine on and turned them acoulpe times to see what all I had to grind.
Old Mar 9, 2011 | 08:27 PM
ParkerSS's Avatar
No I don't and I need to order them and the tires by tomorrow to make it to track day next weekend. Thats why I'm asking so many questions lol. If I go with a 15x10 can I still run a 275 or is that too small?
Old Mar 9, 2011 | 08:43 PM
rob scott's Avatar
if your in a hurry why not buy two spare 16's for the rear and just run a 16" radial and save the money for a better rim if your worried about grinding.
Old Mar 10, 2011 | 03:15 PM
carguy489's Avatar
I bought the 15x8 jegs sport stars which i was told is pretty much the exact same as the summit stars and ive got ls1 brakes and only had to barely grind down a little lip in the middle of the caliper. Took maybe 5 minutes each side. Fit and look great!
Old Mar 10, 2011 | 04:09 PM
TA1364's Avatar
I have 15x8 jegs stars, which are pretty much the same wheel, and I barely had to grind, maybe 5 minutes worth.
