Drag Racing Tech
slicks, tubes or no tubes?
Old Mar 29, 2011 | 12:37 PM
a4ls2goat's Avatar
Default slicks, tubes or no tubes?
i just got some Goodyear Eagle slicks...28x10x15...
they came with tubes, should i leave them on or take them off?
i was running M/T slicks with out tubes....
whats the benefits of tubes?
Old Mar 29, 2011 | 12:51 PM
Scoobysnacks's Avatar
From what I was told the tubes are for guys that like to run the lowest pressure possible in them since it will possibly break the bead seal.
Mostly everyone that I have seen does not run tubes like you did when you had the M/T's. They just dont come with them like your new ones did.
Old Mar 29, 2011 | 12:54 PM
a4ls2goat's Avatar
i just read that the tube can get ripped if the tire spins on the rim do to no screws on the rim, is this true?
Old Mar 29, 2011 | 01:04 PM
Ken95Z28's Avatar
Personally I have never ran tubes.
If the tire is spinning that much on the rim it's possible to break the valve stem on the tub. Typically when installing tubes you will need to put baby powder or similar product on the inside to keep the tubes from sticking to the inside of the tire.
Old Mar 29, 2011 | 01:08 PM
a4ls2goat's Avatar
im gona try them with the tubes to see how they work out...
Old Mar 29, 2011 | 08:56 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
This has been discussed plenty
