Disappointing numbers at track
02 firehawk
Longtubes/borla exhaust
6.24 lift cam
C5z06 heads 102mm manifold and throttle body.. t56 viper transmission pro5.0 shifter, 390 gears..
Rockers pushrods..
Mickey thompson et streets.
My car dynod at 438 to the rear wheel.. On a dynojet. Was at great lakes dragway yesterday an my best time was a 12.6 a bit slower then I anticipated...now I do have the bilstein suspension from slp.. but my axles are stock.
My 60 foot times werent that great I couldn't get 1 faster then 2.0 I was topping out at 116 117 mph at tge end almost every time, anyone have any ideas or helpful hints that will help me hook better? all this power not as much traction as I'd like? Could a sandbag or 2 in hatch help? I really want my 60 foot to 1.8 1.9 I should be low 12's all day.
Thanks for your help
Just want to ask, ET STREET DRAG RADIALS OR Regular ET Streets?
Buy some line lock and practice some launching. You may need shocks to help better control the car, i.e. Adjustible.
Get a line lock, practice your launches. If you are going to continue to run the ten bolt and don't want it to explode, you are gonna have to work on slipping it off the line. you can probably hit 1.7s-1.8s with practice. any more aggressive and it will probably go boom.
when you can, upgrade the rear to something much beefier, install an sfi bellhousing, and run a launch controller. set it to 6k + and have fun!
Look at a MWC 9in. They come with a TQ Arm. But its pretty $$$$. I have a UMI adj. on my junker, Everything is UMI on my car. Most not all but most aftermarket TQ Arms will work on your stock 10 bolt as well as 12 bolts and most 9''s..
What RPM did your car peek at and where are you shifting and how are you shifting?
Every .10 in the 60 is generally about .2 in the 1/4th. So you would have to cut 1.6s or better to even hit 11s and that isnt easy with a T56.
Oh and a 2-step will be your best friend!
http://www.ws6project.com/u
ser_stor/catalog/product_info.php?cPath=235_23_304&products_id=3100
the stock arm is a pos, any thoughts will it help wit hookin?
