Drag Racing Tech
help with my launch please
Old Apr 18, 2011 | 02:00 PM
grn95t/a's Avatar
Default help with my launch please
i think i'm going to try a different rear shock set up and remove the drag bag. right now i have the comp enginering thee way rear shocks, stock springs, umi tunnel mount t/arm @ -2*, relo brackets in the bottom hole, sphon rear drag sway bar, umi solid tubular poly cntrl arms, adj panhard with heim joints and mikey et street radials.
this launch was a 1.57 60'. i am wanting to see some 1.40's so i can run in the 11.20's n/a. then i can open the bottle and really have some fun. was curiuos what you guys running 1.40 sixties think? and are using for shocks?
Old Apr 20, 2011 | 07:35 AM
Old Geezer's Avatar
Wheel spin?
Tried different relo holes?
Air psi experiments?
Looks like decent pitch rotation. If tire spin is not an issue... It'll take more HP to cut that much off the short time..
Try it w/ the bottle, yet?
Old Apr 21, 2011 | 08:45 AM
grn95t/a's Avatar
didn't notice any wheel spin really, felt good. no havent tried the top hole, will have to. did play with the pressure, that launch was at 17psi, went 16, then 15. both times netted a 1.53 60'. have yet to open the bottle, this was the first time out with the new 4400 converter. was just thinking that if she squated abit more i would have better weight transfer and pick up some 60' time, am i wrong in thinking that?
thanks for the input...
Old Apr 21, 2011 | 09:54 AM
ThreeHonks's Avatar
are you leaving off an idle and flashing the stall when leaving or are you trying to stall it up before you push through the brakes?
Old Apr 21, 2011 | 12:17 PM
grn95t/a's Avatar
yes off idle flashing the converter.
Old Apr 21, 2011 | 07:45 PM
RamAir95TA's Avatar
Any front suspension work?
Old Apr 21, 2011 | 08:08 PM
grn95t/a's Avatar
pa racing kmember, stock arms with prothane bushings, qa1 single adj's with 275lbs springs.
Old Apr 22, 2011 | 06:50 AM
ThreeHonks's Avatar
hmmm. it almost looks like its not hitting the tire hard enough, cause it definately is not spinnong.
Could need a little more converter or power, hard to say. Maybe try to leave at like 2000-2200 rpm (elevated idle). I think that may help it flash the converter faster and get it moving instead of leaving off a dead idle
Old Apr 22, 2011 | 07:33 AM
Old Geezer's Avatar
"just thinking that if she squated abit more"
Madman has the answer to that idea!!
"Girls squat, race cars don't."
Old Apr 22, 2011 | 09:43 AM
mad_steve's Avatar
We always run the Double Adjustable AFCO shocks on the front and rear. They will give you the ability to fine tune your suspension, and get the numbers that you're looking for. Call me for more information. 225-673-3533
Thanks!
Steve
Old Apr 23, 2011 | 05:35 PM
grn95t/a's Avatar
deff gonna try that, thanx
nice, madman does know his **** forsure
Thanks!
Steve
thanx steve, will do
